DeeCee
by DeeCee » Wed Mar 05, 2014 12:50 pm
Where can I find a braided clutch hose ?
I am about to change the master and slave cylinders and wish to take the opportunity to change the hose as well.
If available, how much ?
by BRM » Wed Mar 05, 2014 2:05 pm
Hi there,
I've got a stock one lined up to be copied when I have the.time.
Though I'm unsure if the generations have different lengths / fittings.
by SLYDIT » Wed Mar 05, 2014 5:58 pm
949 racing ..they do brake lines too for around the lowest price
by Angreal » Wed Mar 05, 2014 6:39 pm
SLYDIT wrote:949 racing ..they do brake lines too for around the lowest price
Is there a difference between lhd and rhd?
DeeCee
by DeeCee » Wed Mar 05, 2014 6:39 pm
Thanks for the info guys, I will follow up with 949
by SLYDIT » Wed Mar 05, 2014 6:46 pm
na as far as i know only the hard lines are different and they terminate at the same point so the flex is the same.
by WideOpenThrottle » Wed Mar 05, 2014 7:08 pm
Edited
WideOpenThrottle on Thu Mar 06, 2014 4:09 pm, edited 1 time in total.
by marcellarius » Thu Mar 06, 2014 1:21 pm
From what I've read, the clutch hose can be a bit testing to get at with everything in the car. It's certainly not something that is "just there" when changing the hydraulic cylinders
by evel » Thu Mar 06, 2014 5:04 pm
APPARENTLY american braided lines dont meet the requirements for a NZ cert. My boss at work who has imported a few bits (brakes and shit) from the states before told me this.
by marcellarius » Fri Mar 07, 2014 3:39 pm
The rules on this have flip-flopped a bit. I think now they've taken a sensible stance that if it's clearly designed as a brake hose and has crimped/swaged fittings (i.e. the fittings don't screw together onto the hose) then they meet the in service requirements (WOF)...
I don't think you'd run into problems over a clutch hose though.
by SLYDIT » Fri Mar 07, 2014 5:18 pm
I am very confident in using an American brake line. I mean imagine the law suite if one failed due to being sub standard.don't think the u.s suppliers would risk that.
by Snapfrozen » Fri Mar 07, 2014 10:03 pm
SLYDIT wrote:I am very confident in using an American brake line. I mean imagine the law suite if one failed due to being sub standard.don't think the u.s suppliers would risk that.
They contract out of liability
Go with Bridgestone, no problems there
Users browsing this forum: No registered users and 84 guests
