Leak in the Power Steering
PLSEME
Post by PLSEME » Thu Jan 10, 2013 3:36 pm
Hey guys have a 93 NA8, its leaking from the left side of the rack whats the story with these :?: :?:
easy to fix :?:
repair with seal kit myself??? :?: (if one is available)
or just send it away for a rebuild ??? :?: Use the vehicle as a daily driver so cant have it off the road for to long.
Who & what have people found to be the best/easy option.
Thanks :D
Post by WideOpenThrottle » Thu Jan 10, 2013 3:56 pm
Never repaired one myself..only done a de-power on my old rack.
If you can buy the seal kit you would still need set-up instructions & special tools maybe?
Otherwise get an exchange one from a wrecker or send it to the power steering shops local to you.
Post by SLYDIT » Thu Jan 10, 2013 7:40 pm
not a common fault. depending on how long you can live without it either buy another used rack or get yours re sealed.... much of a muchness really.
mazline
Post by mazline » Fri Jan 11, 2013 5:26 pm
Probably worn thru the chrome coating on the rack shaft,Common issue with age.
2 options
Get it to a rack specialist,They will have to rechrome the shaft and then do a seal kit.
second option,
a good condition used rack,Going to be quicker,even know a guy that can out out :wink:
Post by Ian » Sat Jan 12, 2013 8:41 am
Brownie.....a 'guy that can out out' sounds decidedly dodgy! :shock:
mazline
Post by mazline » Sat Jan 12, 2013 12:22 pm
Shouldn't drink and type at the same time !
