PLSEME
by PLSEME » Thu Jan 10, 2013 3:36 pm
Hey guys have a 93 NA8, its leaking from the left side of the rack whats the story with these
easy to fix
repair with seal kit myself???
(if one is available)
or just send it away for a rebuild ???
Use the vehicle as a daily driver so cant have it off the road for to long.
Who & what have people found to be the best/easy option.
by WideOpenThrottle » Thu Jan 10, 2013 3:56 pm
Never repaired one myself..only done a de-power on my old rack.
If you can buy the seal kit you would still need set-up instructions & special tools maybe?
Otherwise get an exchange one from a wrecker or send it to the power steering shops local to you.
by SLYDIT » Thu Jan 10, 2013 7:40 pm
not a common fault. depending on how long you can live without it either buy another used rack or get yours re sealed.... much of a muchness really.
mazline
by mazline » Fri Jan 11, 2013 5:26 pm
Probably worn thru the chrome coating on the rack shaft,Common issue with age.
2 options
Get it to a rack specialist,They will have to rechrome the shaft and then do a seal kit.
second option,
a good condition used rack,Going to be quicker,even know a guy that can out out
by Ian » Sat Jan 12, 2013 8:41 am
Brownie.....a 'guy that can out out' sounds decidedly dodgy!
mazline
by mazline » Sat Jan 12, 2013 12:22 pm
Shouldn't drink and type at the same time !
