question to engine guru's
na6*dori
Post by na6*dori » Sun Aug 12, 2012 11:33 pm
does anybody know the clearances on big end and mains for the na6? using the plastigauge and just want to know what sort of gap tolerances are ok
Any help would be good
Post by WideOpenThrottle » Mon Aug 13, 2012 8:45 pm
Main bearing....main bearing oil clearance-standard=0.018-0.036mm [0.0007-0.0014in].
Maximum...0.10mm [0.004in].
Big end con rod oil clearance....0.028-0.068mm [0.0011-0.0027in]
Side clearance....0.110mm-0.262mm [0.0043-0.0103in]
maximum...0.30mm [0.012in]
As read from my pdf manual.
na6*dori
Post by na6*dori » Mon Aug 13, 2012 11:32 pm
you are a legend, cheers mate. would you also know valve to piston clearance aswell? or is that a negative?
Post by punkoutnz » Tue Aug 14, 2012 8:27 am
The NA6 is a non interference engine as it sits, you'd have to do a fair bit of head grinding for that to change methinks.
Post by WideOpenThrottle » Tue Aug 14, 2012 8:44 am
na6*dori wrote:you are a legend, cheers mate. would you also know valve to piston clearance aswell? or is that a negative?
It doesnt give that info other than the max amount to grind the head is 0.20mm [0.008in] which is also the max grind for the block if that helps.
Users browsing this forum: No registered users and 77 guests
