does anybody know the clearances on big end and mains for the na6? using the plastigauge and just want to know what sort of gap tolerances are ok
Any help would be good
question to engine guru's
Main bearing....main bearing oil clearance-standard=0.018-0.036mm [0.0007-0.0014in].
Maximum...0.10mm [0.004in].
Big end con rod oil clearance....0.028-0.068mm [0.0011-0.0027in]
Side clearance....0.110mm-0.262mm [0.0043-0.0103in]
maximum...0.30mm [0.012in]
As read from my pdf manual.
It doesnt give that info other than the max amount to grind the head is 0.20mm [0.008in] which is also the max grind for the block if that helps.na6*dori wrote:you are a legend, cheers mate. would you also know valve to piston clearance aswell? or is that a negative?
