Sealed Headlights?
Sealed Headlights?
Did only some mx5's come with sealed headlights? I took mine out today to replace the bulb and found it was semi sealed, score
They (NA's)all came out with Sealed Beam head lights,Some Halogen some none Halogen,Halogen give better light,Of course when you blow a bulb you need to change the whole head light unit .
Semi Sealed means you can change just the bulbs ,put wanky ones in if you want,Even better light out put,Thats the one thing they do need at night,Better visibility for you and to been seen from other road users being as low as they are.
I have fully sealed lights in my Mx and at night they
are hopeless, have found some new Semi sealed Hella for $50 each plus bulbs, so hopefully that will improve things
assumption is the mother of all coque ups
I plan to make this my solution when a bulb goes - refer to the post near the bottom http://forum.miata.net/vb/showthread.php?t=426283
Mark, I think you might find that some NZ new NAs had semisealed lights from new...my NA8 did.brownie wrote:They (NA's)all came out with Sealed Beam head lights,Some Halogen some none Halogen,Halogen give better light,Of course when you blow a bulb you need to change the whole head light unit .
Users browsing this forum: Google [Bot] and 6 guests
