Sealed Headlights?
Sealed Headlights?
Post by evel » Wed Jul 04, 2012 8:32 pm
Did only some mx5's come with sealed headlights? I took mine out today to replace the bulb and found it was semi sealed, score 8)
Denz
Post by Denz » Wed Jul 04, 2012 9:15 pm
I have fully sealed went to change them, supercheap wanted $46 and had to order them in, repco $22 and had them in stock, scooore
Post by brownie » Wed Jul 04, 2012 9:32 pm
Semi sealed kits listed in classifieds,Should be no need to run around with average haedlights,
I run Raybrig's myself,Throw out heaps of light with standard H4 bulbs.
Post by evel » Wed Jul 04, 2012 10:08 pm
im assuming fully sealed means you can not just replace the bulb, you have to do the hole unit?
Post by brownie » Wed Jul 04, 2012 10:35 pm
They (NA's)all came out with Sealed Beam head lights,Some Halogen some none Halogen,Halogen give better light,Of course when you blow a bulb you need to change the whole head light unit .
Semi Sealed means you can change just the bulbs ,put wanky ones in if you want,Even better light out put,Thats the one thing they do need at night,Better visibility for you and to been seen from other road users being as low as they are.
Post by evel » Wed Jul 04, 2012 10:47 pm
ok cool, well the guy i brought mine of must of put semi sealeds in
Post by brownie » Wed Jul 04, 2012 10:52 pm
Possibly even done in Japan,I see semi sealed sets come in quite often from Japan thru work,Got 2 sets of the Raybrig clears and one set of Frosted with cool blue bulbs the other day.
And a HID kit to suit H4's...mmmmm wonder how well they will fit my lights :wink:
Post by SLYDIT » Thu Jul 05, 2012 8:10 pm
raybrigs? never heard of them.
also i thought HID kits for normal headlights were illegal?
Post by Angreal » Thu Jul 05, 2012 11:07 pm
I always thought HIDs were illegal also unless used with projectors.
Post by brownie » Thu Jul 05, 2012 11:31 pm
Raybrigs are made by Stanley,one of the bigger OEM light manufactures,
Just had 2 more sets turn up,When i,m ready i will put up a classified add for them,GOOD quality over Tai/China stuff
Big Al
I have fully sealed lights in my Mx and at night they
Post by Big Al » Sat Jul 07, 2012 10:22 pm
are hopeless, have found some new Semi sealed Hella for $50 each plus bulbs, so hopefully that will improve things
assumption is the mother of all coque ups
Post by Angreal » Sat Jul 07, 2012 10:49 pm
I plan to make this my solution when a bulb goes - refer to the post near the bottom http://forum.miata.net/vb/showthread.php?t=426283
Post by Ian » Sun Jul 08, 2012 2:11 pm
brownie wrote:They (NA's)all came out with Sealed Beam head lights,Some Halogen some none Halogen,Halogen give better light,Of course when you blow a bulb you need to change the whole head light unit .
Mark, I think you might find that some NZ new NAs had semisealed lights from new...my NA8 did.
