Emanage Blue software support tool.
Post by Habanero666 » Sun Nov 14, 2010 6:33 pm
Does anyone here still have the greddy emanage software support kit?
I am in need of one.
Jim
Re: Emanage Blue software support tool.
Post by zorruno » Sun Nov 14, 2010 8:48 pm
Habanero666 wrote:Does anyone here still have the greddy emanage software support kit?
Jim
You need the software... and the lead?
I gave Don at Autoway a laptop with the software on it. I have a lead - but I have never tested it - it is apparently an aftermarket one and I'm not sure if it works. You are welcome to try it - I can put on courier...
Post by SLYDIT » Sun Nov 14, 2010 9:55 pm
do you need the lead??
you can download the software from the net. for the Emanage blue you want to be using AT LEAST firmware version 1.25/1.47 respectively for pc and Emanage unit.
i have a lead but am somewhat hesitant to let it out of my sight as i have yet to see a set of injectors that i loaned for a "few days" come back to me...
once bitten etc etc.
Post by Habanero666 » Sun Nov 14, 2010 10:04 pm
SLYDIT wrote:do you need the lead??
Hi there,
Thank you for the tip.
I am trying to find that website to download the software, but cannot. Do you have a link please? ( EDIT) I have found it!
I would imagine the injectors not coming back would piss you off!
Please let me know what the web site is or maybe a link???
Jim
Post by Habanero666 » Sun Nov 14, 2010 10:08 pm
Jim
Thanks once again for your kindness ( I miss it, now dealing with Suzuki forum types:) )
I am looking to purchase (just the lead), I have just seen SLYDIT mention above, about the software being available on the web???
(EDIT) Found it, yah!
I also need to purchase the ignition and injector looms.
Hahahaha, I still am a demanding chap.
cheers :roll: :lol: :lol: :lol: :lol: :lol: :lol:
Post by SLYDIT » Thu Nov 18, 2010 7:57 pm
You do not need to buy both the injector and ignition looms!
the unit comes with plenty of wires in the ignition loom that arent used by the mx5.so just buy that.
you just need to steal a few wires from the ignition plug and put them into the "main" plug to get it all working. you need a SMALL 2mm screwdriver or similar to pick out the wires and place them in.
that will save you some cash.
have a browse around here...
http://www.miataturbo.net/forumdisplay.php?f=10
but be warned they don't like newbs asking "dumb" questions without searching first!
i have some wiring diags and stuff saved in my old old archive files on a spare drive somewhere. let me know if you need any help,it's been a few years since i tackled an install and setup but i'm sure it'll all come back to me...I pretty much know all there is to getting the best out of the emanage blue on a MX5..
I pioneered the NVCS/o2 clamp relay mod that no one else could work out... :wink:
Post by Habanero666 » Thu Nov 18, 2010 9:50 pm
SLYDIT wrote:You do not need to buy both the injector and ignition looms!
Hahaha, this is going in my turboed Suzuki!
Very good point with the wires! I have only to use one wire for the ignition channel as the thing is single disi'ed
Went to a friends workshop and tried to find some plugs to fit it, no luck.
Ok I will check out the link and transhomolagate the data from maz to suz
Post by sprsta » Fri Nov 19, 2010 7:35 am
hey Jim i got an e-01 set up in my car im probably going to remove in the not too distant future. itll probably be better with an e-manage than a link
Gravelben
Post by Gravelben » Sat Nov 20, 2010 12:05 am
Habanero666 wrote:...transhomolagate...
:lol:
Good word!
Post by Habanero666 » Sat Nov 20, 2010 1:16 am
:lol:
Good word!
Hahahaha, I can't beleive I actualy typed that!
I think the word I was after was translate, or words to that effect.
My sincere discambobulations to you Gravelben :lol:
Post by SLYDIT » Mon Nov 22, 2010 9:18 am
I have heard that the stereo headunit plug from a mazda 323 (and others) will fit, but don't know for sure...maybe a trip to pick a part or repco's METRA plug range for some trials is in order?
Basically the standard "main" plug doesnt come with any wires for the injection part so you buy the ignition harness for the plug and a few wires and use all the other wires in the injection part.
Post by Habanero666 » Mon Nov 22, 2010 11:50 am
SLYDIT wrote:I have heard that the stereo headunit plug from a mazda 323 (and others) will fit, but don't know for sure...maybe a trip to pick a part or repco's METRA plug range for some trials is in order?
Ok Thanks for that, I have just ordered the ignition harness, pressure sensor and harness. I have also made up a serial cable from a nokia DKU-5 cable and a USB cable. Just TX,RX and ground needed. I also found and downloaded the software off the net as recommended.
Jim
Post by SLYDIT » Thu Nov 25, 2010 9:12 pm
if you are signed in as a user on miataturbo.net then have a look at this link.
http://www.miataturbo.net/showthread.php?t=485
Post by Habanero666 » Thu Nov 25, 2010 10:02 pm
SLYDIT wrote:if you are signed in as a user on miataturbo.net then have a look at this link.
Thanks again, yes I still visit that forum. Awesome I will have a read now.
