Whats this?
Whats this?
Post by WideOpenThrottle » Mon Oct 05, 2009 8:26 pm
What does it do?
Where does it go?
Can i do without it?
Cheers!
Post by Euen » Mon Oct 05, 2009 8:57 pm
where did you find it?
Are there any part numbers on it?
What are the wire colours going into it? Might help identify what it is.
Post by WideOpenThrottle » Mon Oct 05, 2009 9:32 pm
Yeah I suppose it helps to say that it came off my 89 NA somewhere in the engine bay, but I can't remember where it goes.
Post by Euen » Mon Oct 05, 2009 11:13 pm
If the wires are
White, Brown/yellow, blue, yellow/blue, Black/White, black, brown, red
then it is probably the igniter for the igniton and if you are retaining your standard coils then, yes, you will need it.
Whats this?
Post by poison » Mon Oct 05, 2009 11:22 pm
Looks relay-ish... exciting.... have you any idea where it came from at all?
.... oh I wanna know....
Post by WideOpenThrottle » Tue Oct 06, 2009 9:00 am
It's got no numbers or markings. Doesn't seem to fit the igniter plugs.
Wire colours are 4 yellow, 2 white, 3 red & 4 black. And I suspect it's an after-market device as it doesn't look original Mazda wiring and plugs and also the fuse is a glass tubular one inside a plastic holder.
Time will tell if I need it.
Post by brownie » Tue Oct 06, 2009 11:10 pm
With those connectors it does not look factory to me,I've pulled enough cars apart to have some idea,but can always proved wrong.
Post by Habanero666 » Wed Oct 07, 2009 10:17 am
I have a suspicion that is a switching unit for aftermarket driving lights. :idea: :idea:
