Whats this?
Whats this?
What does it do?
Where does it go?
Can i do without it?
Cheers!
Where does it go?
Cheers!
If the wires are
White, Brown/yellow, blue, yellow/blue, Black/White, black, brown, red
then it is probably the igniter for the igniton and if you are retaining your standard coils then, yes, you will need it.
Whats this?
Looks relay-ish... exciting.... have you any idea where it came from at all?
.... oh I wanna know....
It's got no numbers or markings. Doesn't seem to fit the igniter plugs.
Wire colours are 4 yellow, 2 white, 3 red & 4 black. And I suspect it's an after-market device as it doesn't look original Mazda wiring and plugs and also the fuse is a glass tubular one inside a plastic holder.
Time will tell if I need it.
