Gearbox Gaiter
RD5T3R
Gearbox Gaiter
Post by RD5T3R » Mon Mar 13, 2006 4:07 pm
Greetings All
We have obtained the bits for the gearbox gaiter repair from Ross but are
there any issues I should be aware of before I start?
I know the gear lever is screwed on (BRG V Spec) from underneath somehow so
the rest is just a remove and replace?
Any hints or a idiots guide greatly appreciated
Stu n Viv
RD5T3R
carl.halvorsen
Gearbox Gaiter
Post by carl.halvorsen » Mon Mar 13, 2006 5:00 pm
Presumably you have a Nardi wood gear knob on your BRG V spec. There will be a small grub screw through the metal base of the knob. You will need the correct size allen key to unscrew it.Then you simply unscrew the knob off the lever.>
Date: 2006/03/13 Mon PM 04:07:25 GMT+13:00
Subject: Gearbox Gaiter
Greetings All
We have obtained the bits for the gearbox gaiter repair from Ross but are there any issues I should be aware of before I start?
I know the gear lever is screwed on (BRG V Spec) from underneath somehow so the rest is just a remove and replace?
Stu n Viv
RD5T3R
Regards,
Carl.
Greetings AllWe have obtained the bits for the gearbox gaiter repair from
Ross but are there any issues I should be aware of before I start? I know
rest is just a remove and replace? Any hints or a idiots guide greatly
appreciated Cheers Stu n Viv
RD5T3R
Ross Bryon
Gearbox Gaiter
Post by Ross Bryon » Mon Mar 13, 2006 5:27 pm
Yes, and when you put the knob back on make sure to use LokTite on
the allen grub screw or it will always be loosening on you!
Ross Bryon
1991 BRG V-Spec Roadster | OL MAN |
Auckland
On 13 Mar 2006, at 5:00 PM, <carl.halvorsen@xtra.co.nz>
<carl.halvorsen@xtra.co.nz> wrote:
Return to “2006”
