Greetings All
We have obtained the bits for the gearbox gaiter repair from Ross but are
there any issues I should be aware of before I start?
I know the gear lever is screwed on (BRG V Spec) from underneath somehow so
the rest is just a remove and replace?
Any hints or a idiots guide greatly appreciated
Stu n Viv
RD5T3R
Gearbox Gaiter
Gearbox Gaiter
Presumably you have a Nardi wood gear knob on your BRG V spec. There will be a small grub screw through the metal base of the knob. You will need the correct size allen key to unscrew it.Then you simply unscrew the knob off the lever.>
Carl.
Greetings AllWe have obtained the bits for the gearbox gaiter repair from
Ross but are there any issues I should be aware of before I start? I know
the gear lever is screwed on (BRG V Spec) from underneath somehow so the
rest is just a remove and replace? Any hints or a idiots guide greatly
appreciated Cheers Stu n Viv
RD5T3R
Regards,From: "Stuart Gross" <stugross@ihug.co.nz>
Date: 2006/03/13 Mon PM 04:07:25 GMT+13:00
Subject: Gearbox Gaiter
Greetings All
We have obtained the bits for the gearbox gaiter repair from Ross but are there any issues I should be aware of before I start?
I know the gear lever is screwed on (BRG V Spec) from underneath somehow so the rest is just a remove and replace?
Stu n Viv
RD5T3R
Carl.
RD5T3R
Gearbox Gaiter
Yes, and when you put the knob back on make sure to use LokTite on
the allen grub screw or it will always be loosening on you!
Ross Bryon
1991 BRG V-Spec Roadster | OL MAN |
Auckland
On 13 Mar 2006, at 5:00 PM, <carl.halvorsen@xtra.co.nz>
Ross Bryon
Auckland
