Ajustables
Ajustables
Does any one know if there is a correct proceedure for raising/lowering the ajustable coil-overs on the car and i mean like start fully up then rears first or is it just a case of keep trying? As i adjust one it seems to affect the heights of the other corners! Cheers.
Cheers guys-it was for my sons car & not my MX.As it is only a road car we did it ourselves just by measuring wheel height clearance.Its not perfect but close enough.Incidentaly its made me measure a number of cars now & it seems that most of them have uneven wheel clearance to some degree.
Are you measuring from hub centre to wheel arch? or edge of tyre to wheel arch? Tyres vary a lot (shape, size, wear) so probably shouldn't be used as a datum.WideOpenThrottle wrote:Cheers guys-it was for my sons car & not my MX.As it is only a road car we did it ourselves just by measuring wheel height clearance.Its not perfect but close enough.Incidentaly its made me measure a number of cars now & it seems that most of them have uneven wheel clearance to some degree.
