Ajustables
Ajustables
Post by WideOpenThrottle » Thu Dec 09, 2010 1:33 pm
Does any one know if there is a correct proceedure for raising/lowering the ajustable coil-overs on the car and i mean like start fully up then rears first or is it just a case of keep trying? As i adjust one it seems to affect the heights of the other corners! Cheers.
Post by sprsta » Thu Dec 09, 2010 2:17 pm
do both rears and both fronts at the same time
or find an alignment shop that can do corner weighting
Post by Growler » Mon Dec 13, 2010 2:11 pm
...or hire the corner weights and do it yourself...
Post by WideOpenThrottle » Tue Dec 14, 2010 8:57 am
Cheers guys-it was for my sons car & not my MX.As it is only a road car we did it ourselves just by measuring wheel height clearance.Its not perfect but close enough.Incidentaly its made me measure a number of cars now & it seems that most of them have uneven wheel clearance to some degree.
Post by Timmo » Fri Dec 17, 2010 9:06 am
WideOpenThrottle wrote:Cheers guys-it was for my sons car & not my MX.As it is only a road car we did it ourselves just by measuring wheel height clearance.Its not perfect but close enough.Incidentaly its made me measure a number of cars now & it seems that most of them have uneven wheel clearance to some degree.
Are you measuring from hub centre to wheel arch? or edge of tyre to wheel arch? Tyres vary a lot (shape, size, wear) so probably shouldn't be used as a datum.
Post by WideOpenThrottle » Sat Dec 18, 2010 9:42 am
Good point Timmo-i will re-measure as a point of interest!
Gravelben
Post by Gravelben » Sat Dec 18, 2010 10:54 am
Or measure from the floor to the bottom of the sill/jacking point or something. Guess thats a bit dependent on tyres still.
