Air conditioning compressor
to me it's NOT looks ok. I had big smoke and some melted rubber like substance spraying in inside the engine room and mostly event on the back side of bonnet/hood. It was diagnosed it could be an accessory belt and both are changed. So, that was about month ago and I cleaned the black rubber as much as I can. So, I can see if that happens or if the is still some problem.
With new belt, I saw very small amount but still have this black thing under the bonnet. So I've looking very carefully and bet is OK, but find the front of air conditioner compressor is not sleight. Touching there has this sticky , a black staff that is exactly same as one I found under the bonnet.
Is this means the compressor is totally out or just a seal and refilling the refrigerant and so on?
AC is quite handy to tale hot are out and so on, but I can live without of that cost too much in that case maybe take whole things out...
Appreciate advise or even the photo of your air conditioning compressor will be helpful.
- Attachments
Ben
Kia ora Ben,
It would appear that your problem may be confined to the clutch, rather than the compressor proper. It is impossible to tell without being able to actually examine things. You will have to ask someone who knows their stuff, to physically check it for you.
Trevor.
Trevor.
Trevor.
Thanks, I may bring it to the garage.
A Clutch you mean the magnetic clutch inside the compressor?
My car is actually running fine but I'm bit worried and wondering about what is the black rubbery (more like tar) looking staff in front (inside) of the compressor pulley .
Any input is appreciated.
Ben
Greetings Ben,Ben.Nakagawa wrote:Thanks, I may bring it to the garage.
Yes, I mean the magnetic clutch. The clutch could contain a friction material which could be slipping, overheating and giving off the stuff you describe.
Trevor.
Trevor.
Thanks a heap, Tervor.Trevor wrote: Greetings Ben,
Trevor.
I'll check with local garage and now I have something to tell them what to look for.
Ben
Ben
After a little thinking. I think fixing compressor will be taking quite bit of work in time wise hence more $$ compare to replace it.
This is based on if I can find good working condition second hand compressor.
Not sure if this is good or bad idea...
My question in this post is that if I remove the accessory belt all together for the compressor (I do not have power steering but just an idle pulley. Is this save something or at least not making the existing equipment worth?
Ben
I found a compressor (S/H). Thanks Mark and please hold it little bit longer. I'll get back to you.
I have asked some question at garage regard to retrofit (R12->R134). It is possible but they will get back with some estimate.
Depends on that... I'm still not completely decide to keep the system or ditch them... It's handy when wet as it will clear-up the fog... If the cost is not too much different, I may keep it.
Those of who removed the Air conditioning what was the trigger that you to decide the removal? Obviously weight and track use may be a big factor, but is there any other reason?
Ben
I removed mine to make turbo install easier. Dont miss it at all. Miss my
power steering though.
I LOVE LOVE LOVE my A/C sitting in the sun at the lights, it's a God
send.... my 2 cents.
Re: Air conditioning compressor
That's exactly what I told to the service counter at garage when he asked me how much more are I need when the roof is down.poison wrote:I LOVE LOVE LOVE my A/C sitting in the sun at the lights, it's a God
Has anyone done the conversion from R-12 to R134 gas?
Ben
Got a quote.
To convert to R134 (retrofit, recharge and leak test) is $350.00 +GST.
On top of this, local garage will charge the labour to replace A/C comp (which is not functioning now) .
If I spirit the work in several phase like:
1. De-gassing ( I need to ask this to AC guy)
2. Replacing A/C comp I may be able to do this by myself but I might need more time to obtain correct oil, seals and leak testing and so on.
3. retrofit and either by myself or A/C guy.
4. leak testing by A/C guy before recharging.
5. recharge by A/C guy.
This will be fun but not so fun part is I have non operational car for few days when they can do whole things by one afternoon while I'm working at office.
It's not cheap! I'm so tempting to remove whole thing, but Like poison said, it's quite handy in many ways. I may try to fix just once. Next time it will be ... who knows.
I kind understand it getting the way when you converting to turbo and if that is my goal I'm not hesitate to remove it but this is my daily commuter and I want comfort over the power.
Thanks for all contribute! But it still be interesting what trigged you to remove those unit right? so keep coming!
Ben
New AC comp in and recharged the gas. I think the AC guy converted to R134 gas but no sticker label that indicating the conversion.
I'll check later when invoice is issued.
It working now and very good!
Thanks Mark for providing compressor and everyone for providing idea and support.
Ben
