Effective intercooler plumbing on a diet!
I had a brainstorm!
I thought about using aluminium piping for an Intercooler, but that is just cost prohibitive in N.Z,so.....
Off to the wreckers and have a good old look around at some OEM nissan macaroni.
Well, I think with the pipe bends made by the guys and gals at nissan I could not only save $$$ but actually save weight too!
How?
If you have seen skyline turbo plumbing, you will infact see that it is made of a thin guage steel (thin wall thickness). Much lighter than exhaust tubing! just a few of these factory pipes can provide 100% of the bends required to zap up a set up!
How?
yeah 50mm is 2"
if you were in tauranga id give you a hand to try it out since i have all the stuff here at home, sadly, just before i installed the turbo on my car(to use the copper) i wrecked my back welding up a turbo manifold
that was about 10 months ago and i havnt really worked on cars since
PEace
psycho_Dad
PEace
psycho_Dad
I thank you kindly for your offer.
Back injuries are way too nasty so be sure to not push it!!!
I have opted for steel tubing
(I know slydit will have a chuckle about this !) but it is thin walled and my TIG welder will do the job!
Anyone got good ideas on weight reduction for Mx5 s ???
Weight reduction is like horsepower....only it saves gas and not consumes it!!
Weight reduction is a topic of it’s own, and a good one too. I’ll start a new thread.
[quote="SLYDIT"]chuckle chuckle...
See I knew it!!
Hey I should also mention that I have just about finished the O2 clamp, I have tried to mount the lot onto a pcb to keep it all tidy. I will try every trick in the book to keep it Japanese like in respect to being compact and reliable!
Will send pics to you later!
that sonds good.. i did the same thing.. my final version is about 25mmx40mmx25mm. so it tucks in nicely next to my emanage (which is next to the ECU.) I hope you got a good 25 turn pot so you can get that fine adjustment needed....
Let me know if you have any issues with it at all.
[quote="SLYDIT"]that sonds good.. i did the same thing.. my final version is about 25mmx40mmx25mm. so it tucks in nicely next to my emanage (which is next to the ECU.) I hope you got a good 25 turn pot so you can get that fine adjustment needed....
can't wait to turn her up to 8 psi and see what happens!
