Effective intercooler plumbing on a diet!
Post by Habanero666 » Sun Jan 13, 2008 9:09 am
I had a brainstorm!
I thought about using aluminium piping for an Intercooler, but that is just cost prohibitive in N.Z,so.....
Off to the wreckers and have a good old look around at some OEM nissan macaroni.
Well, I think with the pipe bends made by the guys and gals at nissan I could not only save $$$ but actually save weight too!
How?
If you have seen skyline turbo plumbing, you will infact see that it is made of a thin guage steel (thin wall thickness). Much lighter than exhaust tubing! just a few of these factory pipes can provide 100% of the bends required to zap up a set up!
Psycho_Dad
Post by Psycho_Dad » Sun Jan 13, 2008 11:03 am
how about 50mm copper? i get the bends for about $10 a bend, and they come in 90 and 45 degrees
you can braize it too if you dont like silicone joiners
Peace
Psycho_Dad
Post by Habanero666 » Sun Jan 13, 2008 11:43 am
Thats an idea, copper is an excellent thermal conductor aswell!
I wonder which way heat will go....into the tube....or out??? interesting!!
Might be worth some research.
Have you done this yet?
50mm is about two inchs right?
Psycho_Dad
Post by Psycho_Dad » Wed Jan 16, 2008 8:51 am
yeah 50mm is 2"
if you were in tauranga id give you a hand to try it out since i have all the stuff here at home, sadly, just before i installed the turbo on my car(to use the copper) i wrecked my back welding up a turbo manifold
that was about 10 months ago and i havnt really worked on cars since
PEace
psycho_Dad
Post by Habanero666 » Wed Jan 16, 2008 10:58 am
I thank you kindly for your offer.
Back injuries are way too nasty so be sure to not push it!!!
I have opted for steel tubing :roll: (I know slydit will have a chuckle about this !) but it is thin walled and my TIG welder will do the job!
Anyone got good ideas on weight reduction for Mx5 s ???
Weight reduction is like horsepower....only it saves gas and not consumes it!! :twisted:
Post by poison » Wed Jan 16, 2008 11:30 am
Weight reduction is a topic of it’s own, and a good one too. I’ll start a new thread.
Post by SLYDIT » Wed Jan 16, 2008 8:50 pm
chuckle chuckle... :P
who needs to worry about that last KG of weight savings when you can just crank the boost up another PSI.... HE HE
Post by Habanero666 » Thu Jan 17, 2008 9:22 am
[quote="SLYDIT"]chuckle chuckle... :P
:roll: See I knew it!! :)
Hey I should also mention that I have just about finished the O2 clamp, I have tried to mount the lot onto a pcb to keep it all tidy. I will try every trick in the book to keep it Japanese like in respect to being compact and reliable!
Will send pics to you later!
Post by SLYDIT » Thu Jan 17, 2008 4:07 pm
that sonds good.. i did the same thing.. my final version is about 25mmx40mmx25mm. so it tucks in nicely next to my emanage (which is next to the ECU.) I hope you got a good 25 turn pot so you can get that fine adjustment needed....
Let me know if you have any issues with it at all.
Post by Habanero666 » Thu Jan 17, 2008 4:41 pm
[quote="SLYDIT"]that sonds good.. i did the same thing.. my final version is about 25mmx40mmx25mm. so it tucks in nicely next to my emanage (which is next to the ECU.) I hope you got a good 25 turn pot so you can get that fine adjustment needed....
:twisted: can't wait to turn her up to 8 psi and see what happens!
