Hood repair - Auckland
ross
Post by ross » Fri May 18, 2012 10:38 am
Adjust the clamps to make sure there tight. The roof needs to pull down onto the door glass to make a good seal.
Also ensure your latch noses on the clamps arent broken or missing.This will ensure the hood sits in the clamp mounts in the correct position and also wont rattle.
Pulling the top side hood rubbers together also helps as they tend to move apart.
Finally make sure the door glass is coming up high enough to make a good seal.
I find 5 minutes adjusting cures most leak problems.
Chilling_Silence
Post by Chilling_Silence » Fri May 18, 2012 10:41 am
ross wrote:Pulling the top side hood rubbers together also helps as they tend to move apart.
Yeah they've separated on mine, not entirely sure on how to stretch them, but I figure if I sit down for long enough with that service manual it ought to tell me. The tape I've popped over mine was enough to seal the gap in the rubbers.
The window comes up as high as it can go (Albeit a little slowly at times, I could touch that up), so I'm pretty confident in my situation I just need to work out how to adjust the rubbers.
ross
Post by ross » Fri May 18, 2012 11:05 am
They fit in a channel in the hood frame.Pull them gently together.
Your slow window problem could be gummed up contacts in your window switch.Pull it apart and give it a dose of contact cleaner.
Post by WideOpenThrottle » Fri May 18, 2012 1:20 pm
Make sure your window tops are parallel along the rubber when closed and making even pressure along it.
All the adusment proceedures are in the body section 'S'.
Fleur
Post by Fleur » Fri May 18, 2012 5:39 pm
I have possibly found the problem that is causing my leak. I had a loose seal at the top of the drivers door that was scrunched, causing it to lean on the channel on the door frame. Where it should sit over and into the channel that collects water, it was pushing up against it and hence the water was not falling into the channel, it was falling on me instead.
Here is some pics to show you what I mean.
So we will glue the loose door seal into place over the weekend to stop it moving around and try and work out the squashed channel and see if we can get it sliding neatly into place.
Nice round fat seal where water to run into it.jpg (3.44 KiB) Viewed 16873 times
pulling seal out under so sits correctly.jpg (3.49 KiB) Viewed 16873 times
see how it's squashing the channel.jpg (3.39 KiB) Viewed 16873 times
drivers door channel dry inside.jpg (6.43 KiB) Viewed 16873 times
drivers door channel lower lip squashed.jpg (7.7 KiB) Viewed 16873 times
Users browsing this forum: No registered users and 81 guests
