Adjust the clamps to make sure there tight. The roof needs to pull down onto the door glass to make a good seal.
Also ensure your latch noses on the clamps arent broken or missing.This will ensure the hood sits in the clamp mounts in the correct position and also wont rattle.
Pulling the top side hood rubbers together also helps as they tend to move apart.
Finally make sure the door glass is coming up high enough to make a good seal.
I find 5 minutes adjusting cures most leak problems.
Hood repair - Auckland
ross wrote:Pulling the top side hood rubbers together also helps as they tend to move apart.
Yeah they've separated on mine, not entirely sure on how to stretch them, but I figure if I sit down for long enough with that service manual it ought to tell me. The tape I've popped over mine was enough to seal the gap in the rubbers.
The window comes up as high as it can go (Albeit a little slowly at times, I could touch that up), so I'm pretty confident in my situation I just need to work out how to adjust the rubbers.
I have possibly found the problem that is causing my leak. I had a loose seal at the top of the drivers door that was scrunched, causing it to lean on the channel on the door frame. Where it should sit over and into the channel that collects water, it was pushing up against it and hence the water was not falling into the channel, it was falling on me instead.
Here is some pics to show you what I mean.
So we will glue the loose door seal into place over the weekend to stop it moving around and try and work out the squashed channel and see if we can get it sliding neatly into place.
- Attachments
- Nice round fat seal where water to run into it.jpg (3.44 KiB) Viewed 16877 times
- pulling seal out under so sits correctly.jpg (3.49 KiB) Viewed 16877 times
- see how it's squashing the channel.jpg (3.39 KiB) Viewed 16877 times
- drivers door channel dry inside.jpg (6.43 KiB) Viewed 16877 times
- drivers door channel lower lip squashed.jpg (7.7 KiB) Viewed 16877 times
Users browsing this forum: No registered users and 92 guests
