How much antifreeze do i use
dart6
Post by dart6 » Mon Apr 27, 2015 6:20 pm
How much would i need in my partners 1990 mx5 please
Post by evel » Mon Apr 27, 2015 9:23 pm
50/50 water to Antifreeze. The cooling system takes around 6L so 3L of antifreeze
dart6
Post by dart6 » Tue Apr 28, 2015 6:58 pm
cheers evel
Ransom
Post by Ransom » Tue Apr 28, 2015 9:15 pm
Make sure you run it long enough for the fan to run and the thermostat to open when you are refilling
Avoid getting an airlock they seem a bit fussy on this
Post by Growler » Wed Apr 29, 2015 4:29 pm
Ransom wrote:Make sure you run it long enough for the fan to run and the thermostat to open when you are refilling
Or take the thermostat out and fiil it from there, then top up in the radiator...
