LSD or non LSD
LSD or non LSD
Post by Donovan » Tue Feb 10, 2015 11:33 am
So, bought a car on a whim, and it turns out it had a spare diff in the boot.
you turn one axle and the other turns in the same direction, is that a LSD or non LSD?
Post by marcellarius » Tue Feb 10, 2015 2:14 pm
Could be an LSD or welded up diff.
Can you hold one axle stationary while turning the pinion shaft?
Post by Donovan » Tue Feb 10, 2015 2:20 pm
Yes I can, and can grab both axle and moved them in opposite directions, so guessing that means it is a LSD, not welded.
Post by marcellarius » Tue Feb 10, 2015 2:23 pm
Is it an MX5 diff? The diff spotters guide on miata.net might help with identification.
Post by Donovan » Tue Feb 10, 2015 2:27 pm
Yeah, it's a MX5 unit, will see if I can find that.
Post by Donovan » Tue Feb 10, 2015 2:33 pm
found it, had a look, looks like a 1.6 VLSD.
anybody want to buy a 1.6 VLSD then?
Post by marcellarius » Tue Feb 10, 2015 2:33 pm
If it's a 1.6 diff, the flanges on the stub axles are different between open and VLSD. If it's a 1.8 diff, you can identify a Torsen LSD by looking through the axle holes, or alternatively, by looking through the filler hole and seeing if you can spot the worm gears of a Torsen (if you have stub axles and don't want to pry them out).
edit: oops, too late :)
