I... take that back. After actually getting used to it and spending some time driving it hard it is 100% glitter-covered rainbow-magic gear shifting unicorn. It would be hard to go back.Junkwhale wrote:I think some of the reviews are a bit over the top; it won't turn your car into a magical gear-shifting unicorn...evel wrote:are those short shifters as awesome as everyone makes them out to be? I considering getting one as well.
So thanks to my good man Jose I got to weigh my car. Not bad without me at 975Kg(With 35L of fuel, helmet and a couple tools) and borderline perfect weight balance but also found out Im just over 90Kg which isnt so great...
https://fbcdn-photos-b-a.akamaihd.net/h ... 3ac4de74fe
Also bought a Link ECU and looking around for cams now
Finally got around to giving it a good wash and wax, some of the water marks were really getting to me, though wish I had the money to get it re-painted, love the colour, but stone chips!
I'm quite happy with the result though, next is to take the headlights out and restore them, but that can wait for another day. It is now beer o'clock.
'98 NB V-Special
'04 Axela 20S
'04 Axela 20S
Furai wrote:So thanks to my good man Jose I got to weigh my car. Not bad without me at 975Kg(With 35L of fuel, helmet and a couple tools) and borderline perfect weight balance but also found out Im just over 90Kg which isnt so great...
Fire up the hole saw and angle grinder, plenty of weight to get out of it haha.
Mine is 960kgs with me/race gear in it and a near full tank of gas. 840kgs without me.
What have you done to get it down that far? Also how did it effect the weight balance and do you have a full cage?built4speed wrote:Furai wrote:So thanks to my good man Jose I got to weigh my car. Not bad without me at 975Kg(With 35L of fuel, helmet and a couple tools) and borderline perfect weight balance but also found out Im just over 90Kg which isnt so great...
Im a little reluctant to cut or remove to much as drifting is a contact sport and things like the heavy bumper supports have been left in so hitting things isnt an issue
Its got 50/50 cross weights. Full cage. No top or any of the mountings. Light weight racetech seat.Furai wrote:built4speed wrote:Furai wrote: What have you done to get it down that far? Also how did it effect the weight balance and do you have a full cage?
Because there is a high level of pushing and bump drafting in our racing all the bumper supports remain.
Anything that can be removed inside has been. Stereo support brackets in the dash. Intrusion bars in the doors(cage has bars and doors are cheap). Soft close shit in the doors. Side windows and mechanisms. Moved battery forward and installed one 1/10th the weight of factory. Striped the wiring loom. Made the exhaust out of thin wall tubing. Heaps of other small things.
Spotweld drill bit and a grinder is all you need
Finished the lense [black silicon was a bad idea to glue it on so should have used translucent for a better finished look!] & fitted some side stripes. All I need now is a WOF & rego for my next drive to the track.
Now that sounds like a racecar. Mine is still a daily at the moment hahabuilt4speed wrote:Furai wrote:built4speed wrote: Its got 50/50 cross weights. Full cage. No top or any of the mountings. Light weight racetech seat.
Right. Big progress. Thanks to the brother in law for his rattle gun.
All suspension out, all suspension apart, ready to prep for paint. Not going to deloom until the new motor is in and running - I figure one dumb move at a time. Started putting the accessories on the motor too. Starter and an engine mount so far. Hardest part is torque tolerances and finding the right nuts and bolts.
Updates in 3 consecutive days. This car may just live!
Bay is ready for paint. There will be no more updates until the paint is done. I want a dramatic before and after. Most of the paint is fine and I just scotch brighted it, a few bits I took back to bare metal as they were a tad rough. Car has minor frontal damage. Will pull it out when I put in the steel bumper bar in a few weeks.
Users browsing this forum: Google [Bot] and 28 guests
