mattapo
Post by mattapo » Thu Oct 09, 2014 8:36 pm
they self tune!!!!! I did most of my tuning myself then got jarad in tauranga to add ignition. simple as.
jtsoldier
Post by jtsoldier » Fri Oct 10, 2014 9:41 am
Furai wrote:I wouldnt go a Megasquirt since no one can tune them
To be perfectly correct, most can but most refuse. :(
Post by SLYDIT » Fri Oct 10, 2014 12:27 pm
That are self tuning... you simply load the base setup then set the afr targets into the map. there plenty of reasonable spark maps on the forums. tuning a ms is no harder than any other ecu
Ransom
Post by Ransom » Fri Oct 10, 2014 3:10 pm
Today I went from this....
To this
3 day weekends are great .. nice drive to the beach with the top down
Time to find some shocks that are not 200000km old to improve the ride .. mine are dead ...
Post by siren676 » Fri Oct 10, 2014 5:34 pm
Barely run in :lol: Just make sure the cambelt isnt due
Ransom
Post by Ransom » Fri Oct 10, 2014 6:22 pm
Well due for a cambelt no record of it being done so its on the list
Body is 200000km motor is unknown as its a long nose crank replacement at some point not the 1989 original
Post by evel » Fri Oct 10, 2014 9:46 pm
wow Ranson, you traveled a kilometer... in 500 meters.....
Post by BRM » Wed Oct 15, 2014 5:23 pm
Put this on.
Thanks Ben.
Ben.Nakagawa
Post by Ben.Nakagawa » Sun Oct 26, 2014 3:46 pm
Installed stainless HVAC panel and meter surround.
those are JASS Performance. Vent ring is from Moss Motors.
Roadster by Ben Nakagawa, on Flickr
I had a pealed AC button so polished to clear, that is why lit up green.
Ross's leather dash mat is shrinking a but but nicely hide the clack I have.
It is my todo list in some time in future.
Also sometime in previous life before me, some one obviously attempted to remove meter cluster glass and clack at bottom tab. It's not too obvious when it's all installed in the car but anothe like added to my todo list in the future.
I'm ordering extra meter ring to better fit of that stainless panel on cluster.
Also I'm seriously thinking CabonMiata's aluminium door panel right now.
BTW, bit of silly question, as I just may be not fist time but consciously noticed... For NA user especially early one, your speed meter move when you backing up?
Ben
Post by Furai » Mon Oct 27, 2014 2:36 pm
Broke it. Got sandwiched between 2 D1 cars after one spun.
This is after beating it into shape
So thats most of the money I had saved out the window. Might have to do D1 next year.
Post by SLYDIT » Mon Oct 27, 2014 5:28 pm
oh ouch! any action shots?
Post by Furai » Mon Oct 27, 2014 5:32 pm
Sadly no was only the 10th run or so[/list]
Post by SLYDIT » Mon Oct 27, 2014 6:06 pm
hammer/bog/primer= real dorifto car! :)
Post by Snapfrozen » Mon Oct 27, 2014 6:07 pm
So put in more work today. Got a few pieces off the old motor. Have painted the block and ready to paint the head - both being done together and just masking, way fucking easier.
Also started stripping pieces off the old motor that I'm going to use. Found it much easier getting the correct bolt sizes by taking off a piece at a time and the spare motor is missing the occasional bracket.
Current situation with bits and bobs:
ImageIMAG0183 by Jarred McLachlan, on Flickr
Alternator all ready to go on:
ImageIMAG0184 by Jarred McLachlan, on Flickr
Alternator adjustor - Thanks dremel.
ImageIMAG0185 by Jarred McLachlan, on Flickr
Alternator bracket all prepped for paint:
ImageIMAG0188 by Jarred McLachlan, on Flickr
Test fitted the intake mani which is all ready:
ImageIMAG0178 by Jarred McLachlan, on Flickr
The current situation:
ImageIMAG0190 by Jarred McLachlan, on Flickr
Only the P/S pump and all the auxillary hoses to go on now and she's ready to go in. As for the car I need to do 2 major things -
1. Engine bay - remove the AC hard lines, remove the headlights, sand/clean the bay, paint the bay.
2. Remove the front suspension and subframe to clean/paint that. Will put in new bushes on the front and install grease nipples to make re-greasing them easy. Paint it all and back in.
Hopefully 1 months work with motivation?
Post by MrGrey » Tue Oct 28, 2014 1:43 pm
Furai - I have some orange side repeater lights you are welcome to if you want em'
Post by Furai » Tue Oct 28, 2014 7:49 pm
Cheers MrGrey Ill let you know, Finally Snap get that poor car moving!
Some action shots of the crash
Post by Furai » Tue Oct 28, 2014 7:55 pm
Heres one that shows the force
Post by SkilletKid » Wed Oct 29, 2014 2:38 am
F@*k all kinds of duck. That's a big shunt.
Post by Snapfrozen » Wed Oct 29, 2014 6:15 am
Yep. Just plain sucks. I've got a right guard in red. Wouldn't likely be worth fixing but it's perfectly fine if you need something to daily it for now
Post by 4A-GE » Wed Oct 29, 2014 11:20 am
RFB, etc.
Post by GRUVBB » Wed Oct 29, 2014 5:52 pm
I went to fit my REDBEN radiator slam panel. Once the cap screws and spacers are positioned onto panel I am unable to get bonnet latch to pass through the opening to fit it into position. Also the bonnet release cable retention bracket fits up through the frame work and the panel will not sit flush on engine side. It is proud by about 5 mm and there is nothing on passenger side. Will this not rattle when vibrating due to being elevated on one side. Any pointers appreciated thanks.
Post by Furai » Wed Oct 29, 2014 7:13 pm
GRUVBB wrote:I went to fit my REDBEN radiator slam panel. Once the cap screws and spacers are positioned onto panel I am unable to get bonnet latch to pass through the opening to fit it into position. Also the bonnet release cable retention bracket fits up through the frame work and the panel will not sit flush on engine side. It is proud by about 5 mm and there is nothing on passenger side. Will this not rattle when vibrating due to being elevated on one side. Any pointers appreciated thanks.
Do you have any pictures?
Cheers to Coxie I got some new panels fitted up, looks much better but still needs work. Also fitted the Mazdaspeed comp engine mounts. ($94 from Mazda NZ)
These are the engine mounts I pulled out, Even one of the metal plates is bent.
Post by Snapfrozen » Wed Oct 29, 2014 7:37 pm
Keep those as a trophy ;)
Post by brownie » Thu Oct 30, 2014 1:34 pm
Got my REDBEN panel the week before and doubled the value of it :-),Now just to get around to fitting it
FB Hydropint
Post by REDBEN » Thu Oct 30, 2014 4:25 pm
Looks Great Brownie!
Users browsing this forum: Gialee and 22 guests
