Snapped Key In Door
Snapped Key In Door
Post by GRUVBB » Sun Jul 27, 2014 3:15 pm
Just went to unlock car and key snapped off in drivers door. :( At least it unlocked during the process so able to get in. Pity its raining and cant work on it without getting wet
Post by GRUVBB » Sun Jul 27, 2014 4:30 pm
I was suppoeed to post this understand What Have You Done to Roadster Today... the stem of key is visable in lock but behind the swivel plate. I am unable to grab it with my convenional long nose pliers. Does anyone know how to extract the lock barrel to retrieve it or know of a link showing required technique???
I have been paranoid of this happening for some time due to the ridiculous thickness of the key.
I have spares and have been contemplating fitting keyless entry tor some time. Procrastinating has cost me extra work so dissappointed with myself.
Post by WideOpenThrottle » Sun Jul 27, 2014 7:25 pm
Tweezers?
Post by WideOpenThrottle » Sun Jul 27, 2014 7:36 pm
Or you could drill a tiny hole in the key and then wind in a small long screw and slowly extract the key??? just kidding!..but it may work :D
Otherwise off with the door card and out with the lock and see if it will dis-assemble..from memory I think it might!
JazzLopez
might work
Post by JazzLopez » Sun Jul 27, 2014 10:52 pm
get a thin wire with a barb push the wire down the side of the key, the bard will grab the tip of the key, pull out slowly, the key should come,,,, a bit o crc will help too.... give that a go... happy huntin
Post by SLYDIT » Sun Jul 27, 2014 11:50 pm
super glue and a toothpick!
but dont fuck it up or youll have a toothpick stuck in there too.
Post by WideOpenThrottle » Mon Jul 28, 2014 8:11 am
compressed air might blow it out enough to grab it maybe?
Post by GRUVBB » Mon Jul 28, 2014 5:36 pm
I tried tweezers but they were too wide to fit through the swivel weather plate. I tried a thin pair from a Swiss Army knife but could not apply enough pressure/tension to extract thd remnant of key. I tried to use 2 thin screwdrivers like a pair of chopsticks to no avail. I turned the plate and was able to force the long nose pliers in and successfully remove remove the key without distorting the plate. :lol: Now I need to fastrack the keyless entry project. Luckily I have 2 spare sets of keys so getting another cut is an easy task
Post by Angreal » Mon Jul 28, 2014 6:43 pm
Someone on Clubroadster did something similar to this. Can't find the original post though
Post by SLYDIT » Tue Jul 29, 2014 7:19 pm
i got a new key cut at the locksmiths from the lock code and it turns so much easier than one copied from an old key. if you still have your factory key just take the code in and get one made.
Users browsing this forum: No registered users and 92 guests
