Project: Jenny craigs
Post by chris » Mon Jun 23, 2014 1:43 pm
So.. Now I have another MX5 I figure I might start a little thread, with a few updates and what not.
I picked the car up exactly 9 days ago. And.. well.. this is what it looks like now..
http://i.imgur.com/g6Yo0Ga.jpg
I'm not going to embed it because it will be fucking 10000000 times larger than I intended.
But this is almost where I am up to. More photo goodness to come tonight.
Post by BRM » Mon Jun 23, 2014 1:49 pm
Could have atleast rotated it.
I heard you might need a diff ;)
Post by chris » Mon Jun 23, 2014 1:53 pm
You heard correct ;)
Mazbro?
Post by BRM » Mon Jun 23, 2014 1:56 pm
Mazbro
Post by chris » Mon Jun 23, 2014 3:00 pm
A task for tonight..
Commiting to roadster driving. 20kg un-needed in that hell of a soft top and frame. May as well get it out.
If anyone is after one, please let me know. A little bit of $ and it's theirs!
Post by chris » Mon Jun 23, 2014 3:34 pm
Still need to edit my damn sig.
Also - cage/rollbar/halfcage/doorbars are all going in next week! So a bit of weight will be gained there, but nothing more cutting won't sort out.
I hope.
I still have an ABS unit to delete, but that won't be for a while as I will need to run new brake lines, so whilst I'm there I might as well run some braided lines. Just cause.
Post by chris » Mon Jun 23, 2014 4:08 pm
I just purchased a 52mm thick radiator.
I think that may be a little overkill...
Oops.
Just call me Angreal
Post by Angreal » Mon Jun 23, 2014 6:19 pm
You called? You have abs to come out and go into my car? I'll assume your car is an NA though
Post by chris » Tue Jun 24, 2014 8:57 am
Post by chris » Tue Jun 24, 2014 11:41 am
Oh yeah - got the roll bar out.
Fucking pain in the ass to remove. So that's for sale too. Not asking too much.
Radiator should get here tomorrow, I hope. I am ordering some new sparkplugs, and an oil filter today to get ready for the weigh day!
Unfortunately, weigh day will be pre roll bar/cage.
Post by Skilfil » Tue Jun 24, 2014 12:07 pm
Almost tempted to get those seats off you, foamectamy ftw.
Post by chris » Tue Jun 24, 2014 12:10 pm
Harlan already has dibs on the drivers side, however from what I can see you can swap the drivers/passenger seat from rail to rail.\
So I only have one left.
Just purchased some oil, oil filter, plugs, coolant, I'm actually going to do my best to see what this motor is capable of in stock form
Post by chris » Wed Jun 25, 2014 10:52 am
Also - did spark plug change on it last night, actually made a difference :D Yay!
Now for the more exciting updates...
Pictures!
http://i.imgur.com/6Vh6oIz.jpg
http://i.imgur.com/rDHuL7Q.jpg
Post by chris » Wed Jun 25, 2014 12:54 pm
Radiator arrived today, it's a beast 53mm of pure coolness.
Will be spraying it with a light coat of black to enhance the cooling efficiency.
Mounting will be the er..... fun(?) part...
Post by BRM » Wed Jun 25, 2014 3:06 pm
Why can't you link the pghotos in so we can see them here instead of clicking?
yeah.
I'm that lazy.
and bloody rotate them properly!
Post by chris » Wed Jun 25, 2014 3:25 pm
Because whenever I put hem in here they get sized horribly
Post by BRM » Wed Jun 25, 2014 3:53 pm
Photobucket etc.
gawsh, kid.
Post by warrior » Wed Jun 25, 2014 4:43 pm
This may be a silly question Chris but what are you going to use the car for ? Racing a guess but in what series etc?
Post by Skilfil » Wed Jun 25, 2014 7:15 pm
Should enter ACJS :D
Post by chris » Wed Jun 25, 2014 7:57 pm
Phew! Took the alarm out, removed the factory radiator, drained oil, and removed filter, and a few bits of misc wiring.
Racing, just fun, not entering a class YET.
I might eventually, I just wanted a distraction :)
Post by chris » Thu Jun 26, 2014 9:56 am
Now... Tonight I get the fun task of setting up the new radiator, good timing as the old radiator hoses were phucked.
I will grab some pictures shortly for evidence, but holy hell. Swollen as a shore kid on roids.
Post by chris » Mon Jun 30, 2014 4:41 pm
Car wet weight, 840 (after you remove me from the equation)
Roll bar installation starts tomorrow, shaved the passenger mirror off entirely, once the cage is in, I will get measurements and pull finger on a Project G G string.
And the soft top will be gone for good.
Eeeeek!
Post by Angreal » Mon Jun 30, 2014 5:02 pm
you could just hack your existing top up and make a g string roof?
built4speed
Post by built4speed » Mon Jun 30, 2014 6:06 pm
There must be more weight to gut out if you wanted. Mine must be around 830-840 with a cage and we aren't allowed to go at the car with a hole saw or anything.
Post by chris » Mon Jun 30, 2014 6:11 pm
Yup! There is plenty more weight to get rid of :)
Bearing in mind I have been doing this in 2 weeks, with wanting to drive it each weekend ;D
