by 4A-GE » Tue Jun 17, 2014 3:15 pm
Will NA8 front brakes fit under NA6 14" daisy wheels?
by Angreal » Tue Jun 17, 2014 3:21 pm
Probably. My na8 ran on 14s and the old 14s still fit with the FM LBBK on 15" rotors
by sprsta » Tue Jun 17, 2014 3:27 pm
Angreal wrote:Probably. My na8 ran on 14s and the old 14s still fit with the FM LBBK on 15" rotors
dem some enormous rotors Angreal!
by Angreal » Tue Jun 17, 2014 4:35 pm
Crap. Obviously haven't had enough coffee. 11" (well they're less) NB "sports" brake rotors as they're often referred to as
The 15" is the wheel size I keep looking at
But good spotting
by 4A-GE » Tue Jun 17, 2014 4:49 pm
Ok, that's one vote for maybe...
by marcellarius » Wed Jun 18, 2014 10:23 am
Yes. Yes they will.
[Edit: I'm only talking about the front calipers; I haven't compared rear calipers
The caliper is essentially the same design, it just has a larger diameter rotor and caliper mounting brackets... the back-spacing requirements are the same.
The only real difference between the NA6 and NA8 caliper is that the big hole and small hole were swapped. You don't even need new calipers to do the NA8 brake upgrade, you can swap the left and right mounting brackets over. I don't know Mazda's reasons for the change.
Usual legal bullshit: this brake modification requires a LVV cert. It's unlikely that anybody will ever notice at a WOF, but may have some insurance implications yada yada yada
by 4A-GE » Wed Jun 18, 2014 10:40 am
Oh. Requires a cert? Fuck that.
- I only think 5.
by warrior » Wed Jun 18, 2014 11:29 am
You wont need a cert...........know one will even notice them
by 4A-GE » Wed Jun 18, 2014 12:31 pm
That's what I was thinking..........
by siren676 » Wed Jun 18, 2014 5:40 pm
Bigger brakes do require a cert even if you are using factory stuff unfortunately, ran into that problem on my starlet when my wof guy noticed i'd put the bigger glanza disks and calliper carriers on it
- I only think 5.
by warrior » Wed Jun 18, 2014 5:49 pm
You always take the chance but I bet no one will notice.
by GRUVBB » Wed Jun 18, 2014 6:07 pm
warrior wrote:You always take the chance but I bet no one will notice.
Except Maybe Sirens WOF man.
