The garage thread
The garage thread
Post by BRM » Fri Jun 13, 2014 9:49 pm
Again..
Starting one of these,
People like sheds which is awesome!
We started with hiring a shitty little thing close the pukekohe track hairpin..
Then brought this
Guess that's the biggest comparison shot I have,
Always have been to busy to stop and take pictures as we go.
Can see what we've done there, taken the ceiling back, was the lounge but now storage,
Lets in a Lot more light, which was what we're after,
as much natural light as possible,
The right hand side wall was taken back too, to the door, there was a box steel pole there, but we had that moved to the far wall side.
This picture above, there was a low ceiling, about 200mm,
we de nailed up, lifted it then gibbed everything with the fire proof gib.
And that's what we're up to now.
Finish that wall,
Sand and paint the floor,
Finalize there machines and benches go..
Yup.
Post by MrGrey » Sat Jun 14, 2014 12:08 am
looks great!
Post by Angreal » Sat Jun 14, 2014 7:41 am
That blue press 8)
Post by Timmo » Sun Jun 15, 2014 10:40 am
Wait....corvette + a silver Mx5, are you 'fiatracer' by another name?
Post by 4A-GE » Sun Jun 15, 2014 1:58 pm
This is my garage.
Post by warrior » Sun Jun 15, 2014 2:06 pm
Roomy
Post by BRM » Sun Jun 15, 2014 5:49 pm
Timmo wrote:Wait....corvette + a silver Mx5, are you 'fiatracer' by another name?
+ a R32 + soon to be RX7.
No, that's not me
Post by GRUVBB » Sun Jun 15, 2014 9:27 pm
warrior wrote:Roomy
And plenty of natural lighting. :lol:
Post by sprsta » Mon Jun 16, 2014 3:43 pm
looking forward to RX7 arriving!
laserracer
Post by laserracer » Tue Jun 17, 2014 11:33 am
Convertible car ..Convertible Garage
Post by GRUVBB » Sat Jun 21, 2014 12:14 pm
For anyone building up a workshop there are a couple of factors to consider if installing fluorescent lighting.
Use a twin fitting as you get stroboscopic effect from a single tube. That is like a timing light. The lamp can flicker at a frequency which around moving machinery can make it appear stationary. Critical around lathes, drilling machines, mills and other rotating equipment. Same if one of the tubes has failed in a twin fitting. The twin fittings illuminate the lamps out of synch with each other to overcome this. Another way is to have an incandescent lamp running at same time.
Fluro lamps also come in a variety of different colours depending on the Kelvin Temperature rating of them. This dictates which section of the light spectrum they radiate. Different tasks require a different light.
Be aware that the new energy saving lamps that fit into a conventional light fitting are actually miniature fluro lamps.
Post by CordedBowl » Sat Jun 21, 2014 5:58 pm
Good info GRUVBB, have karma for the useful insight!
Post by marcellarius » Mon Jun 23, 2014 1:30 pm
Modern compact fluorescent lamps (energy savers) use an electronic ballast which has a much higher frequency than the magnetic ballasts used in old fluorescent tubes, which substantially reduces the stroboscopic effects.
Post by SLYDIT » Mon Jun 23, 2014 6:39 pm
be very careful of fluoro's all together ESPECIALLY if you plan of having the good ol workshop radio. some fittings kill your radio reception. check before purchase if they pass the RFI test.
Users browsing this forum: Bing [Bot] and 59 guests
