Importing automotive parts
Sorry for being a little of mx5 track with this..... I need a new rear mono shock for my road bike. I cant seem to get what I want in NZ within a reasonable time frame. I have a price of £300 to supply and £40 freight for a replacement from the UK. My queery is would I be expected to pay any tax/duty/gst or other hidden costs when it arrives here in NZ. I know there are plenty of folks who have brought in components and should be able to give me sound advice on this one. Thanks in advance. Thats GRUVBB!
It's luck of the draw. I've been able to bring in $500 worth of stuff in one shipment and not get pinged.
I think higher prices and frequency will make them find you easier though (they had no trouble finding my wheels =[ )
The regulation is $400NZD including freight, anything over and above that, customs have the RIGHT to charge GST and duty, and there is the magical word, right, anything over that is the luck of the draw whether they do or don't, however the more you are over, the more likely you will get stung.
There is one way around it, and that is whoever is shipping the parts, puts the value down as a lesser amount on the export documents, so it works out less than the $400 thresshould, however, if the items go astray, all you will be able to claim back is what was on those docs, not what you paid.
To be nitpicky, I think the situation is that if GST + duty is $60 or more, then Customs can require it to be paid. If there is no duty, this gives the $400 threshold, but it would be lower for imports like booze.Donovan wrote:The regulation is $400NZD including freight, anything over and above that, customs have the RIGHT to charge GST and duty
There is different duty rates on items, second hand car parts for example incur no duty, new car parts incur a different duty rate to electronics, etc.
It also makes a difference how they look at it, if you put a business address or home address.
http://www.customs.govt.nz/features/cha ... fault.aspx
http://www.customs.govt.nz/incommercial ... fault.aspx
If you wanna be safe about it, its best to go through whatsmyduty.
Does the calculating of stuff for you, then you know for sure either way what your obligations might be. Including registering to import items over $1k, etc.
