by Junkwhale » Sun Jan 26, 2014 10:49 am
Took off my spare wheel yesterday and discovered some dreaded brown stuff!
Pics:
Worst part:
Some of this is rust stain from the spare:
underneath:
I think it's a bit worse than it looks as some of it's just staining from rust on the edge of the spare wheel rim, and the panel/metal still looks pretty solid from underneath (last pic)
What are my options for dealing to this? I'm tempted to go with masking it off then sanding down the rusted bits, use some rust converter, then prime/paint over it. Is that a good idea though?
Toolbox
by Toolbox » Sun Jan 26, 2014 11:06 am
I would check under your parcel tray carpet first, it looks like to me your roof rain rail is leaking and needs a new one. I have seen this problem too many times lately.
by MrGrey » Sun Jan 26, 2014 11:06 am
Yes that is a good idea. I would also give it a good scrub with a wire brush if you have one.
by SLYDIT » Sun Jan 26, 2014 11:20 am
Paint some por15 on it. Problem solved.
by Junkwhale » Sun Jan 26, 2014 11:22 am
Toolbox wrote:I would check under your parcel tray carpet first, it looks like to me your roof rain rail is leaking and needs a new one. I have seen this problem too many times lately.
You guessed it - actually took my soft-top off completely yesterday (posted this in the other thread just before):
by Junkwhale » Sun Jan 26, 2014 11:44 am
SLYDIT wrote:Paint some por15 on it. Problem solved.
Looks like good stuff. I've used rust converter previously with ok results. Is por 15 better?
The spraystore here in chch is listed as a distributor, so should be able to pick some up
- I only think 5.
by warrior » Sun Jan 26, 2014 3:08 pm
Yeah it is great
