by 4A-GE » Sat Jan 04, 2014 5:49 pm
Ok, so today I tore my old factory radio out because it was sitting under the
actual head unit doing nothing. When I got it out, the wires had been cut and all sorts. The catch is that now I need one of those plastic pocket things to go where the old radio was.
Does anyone have one kicking about? I went to super cheap today for most of the cans of degreaser they had and the cubby things didn't fit
Gearstick boot thing is also a bit whorey so a non-torn one of those wouldn't go amiss either, if anyone has one lying around.
Pics for reference:
by MrGrey » Sat Jan 04, 2014 7:18 pm
sadly a standard size cubbyhole thingy is to small and a lot of people fillthe 20mm gap with rubber or a small piece of wood (painted). How good are your fabrication skills? if it was my car, I would make one myself out of plastic or timber (plastic if I could find a suitably sized plastic container to cut up) and then paint it black, then permanently affix it in place with a nice seam of black silicon at the lip so it seamlessly blends in with the dash and looks like a factory fixture.
or maybe ebay....
-=edit=- if it helps, this is what I did with mine. I would have preferred a cubbyhole, but I had the blank lying around and had the spare roadster badge from debadging the rear garnish. the strip above the radio was made of rubber strip from bunnings (like what you use to stick on a door frame to stop slamming). As you can see, I still have a small gap, but this is never seen due to the angle you sit at.
by SLYDIT » Sat Jan 04, 2014 8:45 pm
i whipped down to pick a part and got a cubby from a late 80's 626/telstar double din cubby. cut it down to size (just had to trim a bit off the top to make it shorter) and simply siliconed it in place. looks factory
by MrGrey » Sat Jan 04, 2014 9:53 pm
brilliant idea!
by SLYDIT » Sat Jan 04, 2014 10:56 pm
just put some big silicon blobs on that internal steel bit that holds the stereo.
NicF
by NicF » Sun Jan 05, 2014 9:01 am
MrGrey wrote:sadly a standard size cubbyhole thingy is to small and a lot of people fillthe 20mm gap with rubber or a small piece of wood (painted). How good are your fabrication skills? if it was my car, I would make one myself out of plastic or timber (plastic if I could find a suitably sized plastic container to cut up) and then paint it black, then permanently affix it in place with a nice seam of black silicon at the lip so it seamlessly blends in with the dash and looks like a factory fixture.
or maybe ebay....
Wot, no carbon wrap? MrGrey, I'm disappointed!
broomfish
by broomfish » Sun Jan 05, 2014 10:31 am
I found a guy selling various models on trademe that had sizes listed and bought the closest one, think it was a toyota one?
by 4A-GE » Sun Jan 05, 2014 10:34 am
Slydit and broomfish are winning. Can't believe I didn't think to look on tardme.
by evel » Sun Jan 05, 2014 11:49 am
leave it with the gap because race car
by 4A-GE » Sun Jan 05, 2014 3:10 pm
See I would, but there's also a gap in my power band.
Found one that fits but has a gap - It came with a couple of front face ring thingies so I wedged the two unused ones underneath to [mostly] hide said gap.
Simonmx5
by Simonmx5 » Mon Jan 06, 2014 12:21 pm
Where did you find it? I'm also in need of a radio gap filler.
by 4A-GE » Mon Jan 06, 2014 2:20 pm
SCA. Brand is acepro. $40 universal thingy.
