V8 conversion
Adrian
V8 conversion
Post by Adrian » Fri Jan 03, 2014 1:53 am
Hi, new to this site and just thought I'd let whoevers out there know that I am well under way into fitting a early toyota 4v alloy v8 into a NA. Just got motor back from reconditioners and is mounted on the subframe. Engine bay is prepped and ready. Gearbox is W55, have had to fab a fair bit. Bell housing, sump, engine mounts, headers, etc.
Will try to post some pics if anyone is interested. Cheers.
Post by MrGrey » Fri Jan 03, 2014 1:59 am
Very interested :)
I'd love to see some pics (the forum will make you wait a lil while before you can post pics)
Post by CordedBowl » Fri Jan 03, 2014 2:22 am
Definitely keen for photos!
Post by SLYDIT » Fri Jan 03, 2014 1:54 pm
there is a couple of 1UZ mx5's running around nz at the moment. there was a white one that used to do track days etc...great swap IMO
Adrian
V8 conversion
Post by Adrian » Fri Jan 03, 2014 3:27 pm
3.4 lt toyota hemi. Still lots to do but I'm getting there.
Adrian
V8 conversion
Post by Adrian » Fri Jan 03, 2014 3:29 pm
one more.
Adrian
Post by Adrian » Fri Jan 03, 2014 3:36 pm
and another.
Post by CordedBowl » Fri Jan 03, 2014 3:57 pm
DANG.
Post by MrGrey » Fri Jan 03, 2014 4:03 pm
a work of art, tis a thing of beauty!
Post by SLYDIT » Fri Jan 03, 2014 4:26 pm
looks great!
make sure you hook up the power plant frame form the diff to the gearbox back up. its an integral part of the drivetrain.
Adrian
Post by Adrian » Fri Jan 03, 2014 5:03 pm
Next job on the list is the gearbox mount. Have welded reinforcing plates onto both sides of the tunnel and will use these to bolt up cross member. The original frame will then be incorporated into that member.
After that its finish the exhaust (really tight on the drivers side), modify the power steer hoses, make a drive shaft, get a bigger radiator made and saving the worse bit for last, move the clutch cylinder. Lots of other minor things but nothing too major. Will need to do a bit of surgery on the bonnet to clear the carb and air cleaner.
Post by 4A-GE » Fri Jan 03, 2014 5:54 pm
Does the car match the rocker covers?
This is seriously cool, good change from the LS1 swaps everyone seems to go on about.
Post by BRM » Fri Jan 03, 2014 6:23 pm
Theres a reason people do LS swaps..
simple
V8 conversion
Post by simple » Fri Jan 03, 2014 7:23 pm
That's true - there often are reasons why people do things - what do you think might be the reason that people do LS swaps?
I like to do things just randomly, hence this post. No, just kidding - I am actually curious. I have no intention of doing any engine swaps, but I do find it interesting to read the tales here, and I like the posts that actually contain content.
mjrstar
Post by mjrstar » Fri Jan 03, 2014 7:49 pm
SLYDIT wrote:looks great!
surely if you are remounting the diff and gearbox the best place for the ppf would be in the bin!!
Post by Snapfrozen » Fri Jan 03, 2014 8:15 pm
You'd need something. With that much custom fab work I think the answer is obvious... custom :)
Post by 4A-GE » Sat Jan 04, 2014 2:31 am
BRM wrote:Theres a reason people do LS swaps..
There are also reasons people put 25det's in skylines and silvias, but you can find those anywhere. I didn't even know Toyota made a v8 that small.
Adrian
Post by Adrian » Sat Jan 04, 2014 6:33 am
I did consider a few engines before choosing this one. The LS, UZ, even god forbid, a rover!! and to be honest if I someone wanted one built I would steer them towards the LS or UZ. The chev is 100 mm narrower across the rocker covers which would have made things much easier.
The attraction towards the little toyota was because it looks cool, its got a carb and dizzy, ( old school I know) and as far as I know, no one has put one in a mx5 before. I do like to be different.
Being such an oddball engine does mean parts are not easy to find, the crank had to be reground to suit the mix of bmw and holden sunbird bearings which were the closest to original. Modified a chev balancer to make pulley choices easier. These were only put out as autos so made the pressure plate to suit the biggest clutch I could fit in.
Hope that helps and no, car does not match rocker covers, its just plain old green.
Post by 4A-GE » Sat Jan 04, 2014 10:56 am
I bet that's just the start of the list of shit you had to make or modify yourself, isn't it? :o
Subscribed to thread. 8)
Post by chris » Mon Jan 06, 2014 9:04 am
1uz is a great engine.. For what you pay..
LS engine platforms will offer you a lot more aftermarket support as well has the possibility for insane horse powers.
Post by Donovan » Tue Jan 07, 2014 1:36 pm
didn't realise people went on about LS swaps in MX5's. Pretty sure there is a lot more 1UZ conversion's running around in NZ than LS conversion's (3 that I am aware off including mine).
I too looked at the Rover (light, cheap, but wast of time horsepower wise), 1UZ, and LS conversion, and went with the LS for one reason alone, POOOOWWWWEEEERRR. As Chris said, insane amount of HP out of them before even going to forced induction, but not cheap. 1UZ conversion is about a 1/4 of the cost of the LS conversion. And GM parts aren't all the cheap, better getting them from the US, but still not cheap after all the other add on's.
Post by 4A-GE » Tue Jan 07, 2014 1:42 pm
Donovan wrote:didn't realise people went on about LS swaps in MX5's.
Welp, too much /o/ for me.
Post by Skilfil » Tue Jan 07, 2014 2:47 pm
Yes I've seen you on there in the post your car threads, and reddit :lol:
Post by 4A-GE » Tue Jan 07, 2014 3:25 pm
Skilfil wrote:Yes I've seen you on there in the post your car threads, and reddit :lol:
PM me to confirm.
Simonmx5
Post by Simonmx5 » Wed Jan 08, 2014 9:03 am
Reddit you say?
Users browsing this forum: No registered users and 391 guests
