1600 to 1800 diff upgrade
Post by WideOpenThrottle » Sat Dec 21, 2013 5:31 am
Anybody know if I need just the half-shafts only and keep my CV's or do i swap the complete axles including CV joints as well?
Many thanks
Post by WideOpenThrottle » Sat Dec 21, 2013 9:23 am
Ok!...now that I have the 1600 driveshafts out it seems obvious to use the 1600 CV's as the 1800 CV's are slightly different in that the outer part of the CV where it goes into the hub is chamfered so will probably not fit right.
I only need the shaft between the diff and the CV,which is shorter to allow for the wider 1800 diff.
Post by SLYDIT » Sat Dec 21, 2013 12:37 pm
are you talking about inner or outer CV's?
Post by WideOpenThrottle » Sat Dec 21, 2013 12:46 pm
Actually! excuse my analogy but its the stub axle ends that are different so all I need to do is put my 1600 stub axle/cv's complete on to the 1800 half-shafts by the looks of it!
Post by WideOpenThrottle » Sat Dec 21, 2013 4:04 pm
Due to the old 1600 CV's having done nearly 300 thou km and feeling rather tight and notchy I think while I am at it new ones would be a good idea! Hope BNT or ADL have some on Monday!....Repco couldn't help.
As usual a bit of chassis cleaning and painting while I have the clearance.
1800 drive shaft now in and just about to bolt up the bigger dif
Post by 4A-GE » Sat Dec 21, 2013 4:43 pm
Pardon my ignorance - What's the benefit of the 1800 diff?
Post by WideOpenThrottle » Sat Dec 21, 2013 5:37 pm
Changes from a 6" to 7" so is bigger,can handle more power and fairly bullet-proof so I have been told.
Also the ratio is 4.1 as against 4.3 for the 1600 so is slightly taller and will give me a higher speed in all gears.
Downside if its relevant is extra weight & possibly slower on take-off but with my boosted engine I doubt if it will be noticeable plus might use a bit more in fuel.
Post by WideOpenThrottle » Tue Dec 24, 2013 7:24 pm
Diff is in plus new rear outer CV'/stub axles and took out the rear muffler so now its got a straight pipe which exits on the passenger side-made the exhaust hangers out of some 200mm galv nails that I had lying around...only need to paint that now.And blow me down went to take it for a test drive and the rear wheel/s were locked up,thought it was something to do with the newer driveshafts or cv's.As it turned out I had a locked drivers-side rear brake pad caused by sticky/ceased calliper pins so all good now!
Test drive to come.
Post by Angreal » Tue Dec 24, 2013 7:40 pm
Plus you get more options regarding lsds. There's torsens and numerous clutch types out there for the larger diff. The only lsds I'm aware of is the cusco for the 6 inch diff (and the viscous I guess).
Post by CordedBowl » Tue Dec 24, 2013 8:02 pm
4A-GE wrote:Pardon my ignorance - What's the benefit of the 1800 diff?
Better skidz G!
Joel
Post by Joel » Tue Dec 24, 2013 8:54 pm
Better skidz G!
Realistically the ONLY reason to upgrade
ch4ng
Post by ch4ng » Wed Dec 25, 2013 4:08 pm
You can also get a Mazdaspeed and Tomei LSD for the 6 inch
El Tigre NA6T
Post by 4A-GE » Wed Dec 25, 2013 9:30 pm
Can I get a meatball 6 inch?
8)
Post by Angreal » Wed Dec 25, 2013 11:54 pm
4A-GE wrote:Can I get a meatball
You'll end up with that if you wreck your diff :lol:
Post by 4A-GE » Thu Dec 26, 2013 9:58 am
I thought the trick with that was to stick a banana in it? I mean, I'd rather that than a whole bunch (har har) of pissed off italians.
Post by WideOpenThrottle » Thu Dec 26, 2013 10:44 am
Just done a 10k test run and all is fine...seems a lot smoother and quieter with more bite to the rear wheels...only I couldn't to a proper acceleration test even in a straight line as I was starting to lose traction in the wet and I have 8mm of tread on my road tyres.
Will be interesting on my next track day.
Post by Furai » Thu Dec 26, 2013 2:38 pm
Joel wrote:
Better skidz G!
Apart from blowing the 1600 diffs if you have power or drive abusively Haha
