I think I've killed my engine
So my engine got a bit hot on the way home last night, didn't quite go to the end of the temp gauge but it got pretty close. There was lots of gurgling noises when I turned it off but no coolant lost. The other Problem is that it's dropped a bunch of oil, looks like it has leaked out the front crank seal area, I could actually see it dripping on to the garage floor and it left a decent sized puddle after being parked for a couple of hours. Any ideas what could be going on and whether these events would be related?
Looks a bit milky in the oil cap but I'm told this may be from condensation. unfortunately I haven't had a chance to have a good look at it or even start it up again, pretty much just parked it in the garage last night and left it there.BRM wrote:Is the oil milky?
Chris, yeah I saw that this morning, don't let that thing go, I might need it!
Yeah I figured it's probably the seal. I've just never seen one get so bad that it leaks this much oil. It let out probably about 500ml's over a couple hours sitting in the garage.Mr. Shine wrote:I would guess you have a... surprise, surprise... leaking front crankshaft seal.
That'd probably be the best place to start.
Also doesn't explain the over heating.
Yeah I got that sorted. So far I've replaced both heater hoses and both lower radiator hoses. The top hose looks pretty old but it's not leaking or anything.marcellarius wrote:You posted about a failed coolant hose a couple of weeks ago, did you get that sorted out? Perhaps the oil seal failed as a result of overheating?
Degrease every thing you can, go for a drive
See where it's leaking from.
If crank seal, expect a solid half day and may aswell change cambelt and water pump while you're in there
(crank / cam seals normally come in cambelt kit)
Overheating..
Check stupid cap hose at the back of the block and hoses around thermostat..
things and stuff.
Good luck have fun.
Overheating..
things and stuff.
Good luck have fun.
Well it seems ok now. It was low on coolant last night when I checked it. Got it up to temperature and took it for a decent drive, no overheating...
Oil level was down just a touch but it doesn't look like oil and coolant have mixed. The front crank seal is leaking, I wonder if the overheating made it leak a bit more.
The top rad hose is now looking a bit tired so I'm going to change that and chuck a new thermostat in it.
