Right off mx5 topic
Right off mx5 topic
I need a bit of help with my home theatre setup, I hope this is ok to put this on here?
I have a home theatre amp and the out signal for the sub is for a RCA lead, the problem is that my sub has just speaker cables. Can I marry to two together?
Any help would be good.
If this is not meant to be on here then I am sorry and just ignore this post.
an RCA plug is simply just a style of plug and you would have no hassles wiring them together.... just get a pair of female RCA plugs from dick smith and unleash a little soldering skill... the positive signal goes to the center and the negative (earth) solders onto the outer sleeve bit.
this pic shows how it should look like after soldering.
any more questions just ask
Your conductor could be encased in a hard plastic dielectric with a thin screen surrounding it and then an outer layer of insulation. Without seeing a pic I am not recommending anything for safety sake.
Is your sub passive or has it got a built in amp?.... Does it plug into a wall socket as well as connection from amp?
I'm assuming you're talking about an amplifier/decoder/whatsit like this:
It's very unlikely that an RCA connector would be used for an amplified output on an amp like this.
If it's a home theatre in a box sort of thing, and it uses RCA connectors for the speakers, then wiring up a cable could work. I'd be inclined to just find/buy a cheap cable ( http://www.cablesdirect.co.nz/catalog/e ... e_number=1 ) and cut an end off rather than soldering a plug onto some speaker cable.
I've never seen speaker power leads in an RCA format, the coax cable and RCA plug aren't designed to carry much current. I would suspect you need a separate amplifier between the receiver and sub. Cheap enough if you don't want to rattle your windows.
A word of warning, assuming your receiver sub out is outputting preamp only and not full power, it will be designed for a high impedance load, like the input stage of an amplifier. Hooking it up direct to a low impedance like a sub may cook the preamp in your receiver.
