Help - Automatic NA6 Christchurch
Hi, I have been converting my 1993 NA 1.6 MX5 to electric, and am nearly ready to take it for certification. It is very slightly heavier than it was originally, but it will be OK, if I can show the weight of a standard model with all the options fitted.
What I would like to do is borrow an Automatic 1.6 MX5 with AC and power steering, and take it over a weighbridge to get the weight. I can borrow a Hard Top temporarily to get the maximum weight.
If anyone in Christchurch or nearby can help me it would be much appreciated. I will fill it up with fuel for you.
My number is 021 503020
John
John
The torque is 100Nm from 0 to 4200rpm, then it tapers off. Which is different from the curve around 5000 rpm with the original engine. The power is 74kW.
What this means is that it is quite different to drive as you have full torque from when the motor is stopped. I don't need to use the clutch to start or stop. It will pull away from completely stopped in 5th gear. You can drive it like a conventional car using all the gears and the acceleration will be better than standard. Alternatively I have found 3rd gear is really good around town and I just leave it there unless I am in a hurry. 5th gear is great on the open road.
Currently the range is about 130km on a charge with a 50/50 mix of town and open road. This still leaves another 20% reserve in the batteries. The cost do travel this distance is about $3.50 in electricity. There is an exemption for road user charges foe electric vehicles until 2020, so there are no other costs.
Charging from my wall socket will take about 7 hours overnight. The batteries are capable of being fully charged in 20 minutes, I just don't have a power source capable of doing it at home. Realistically it can't really travel city to city. But is ideal for someone with a long commute.
You would be absolutely amazed how good the electric motor performs compared to petrol. The torque is always there and they are so silent and smooth. The motor is tiny as well only 225mm diameter and 350mm long with roller bearings at each end and no wearing parts.
I absolutely love the idea of an electric car!
Yours has an almost factory finish under the bonnet, well done.
No doubt quite satisfying to drive about.
I very rarely travel more than 130km in a day but if I did (at my current mileage rate) it would cost me $23...
I'm sure you get peppered with questions about it all the time but it is a very exciting prospect as fuel prices will only ever go up!
I assume you still have wof & rego, what about a electric cert like what camper vans need for 240v hook up? -Ive heard about them but dunno what it is?
I guess the biggest argument against is battery lifespan/replacement and disposal, yours look brand new so what can you expect out of them?
At present I am getting ready for certification. There are a set of regulations that need to be followed available from LVVTA.
I don't an electrical WOF as the charger wont be installed in the car and therefore no mains voltage will be in the car. After Certification I will just need to get standard WOF and Reg.
The batteries will reduce in capacity to 80% after 3000 charges. If I charge it twice a week the batteries will last about 28 years.
3000 charges before the batts even drop to 80%!!jspence wrote:The batteries will reduce in capacity to 80% after 3000 charges. If I charge it twice a week the batteries will last about 28 years.
Now I failed maths but my calculator tells me at 130km per charge is 390000km.
Ok and at $3.50 a charge that equals $10,500.
To do the same distance with petrol (at 0.18c per km) equals $70,200!!
And that .18c amount is if your MX5 actually does 450km a tank!
Have I worked that out correctly?!
plus there's no oils changes, spark plugs, coolant....
