Mazda 323 GTX PCV valve
I am after a mazda 323 gtx pcv valve (the one that goes into the rocker cover) I have contacted mazda NZ but without a rego number they are not much help.
I am going to install in on my supercharged car and it is ment to give another 1psi.
Does any one know where I can get one from or do the have a part number for one?
Any help would be great.
Probably to some degree as I think it has a stronger spring in it.When I had my turbo'd high mileage engine I ran it without a pcv valve,blanked off the manifold and put a filter on the rocker cover so that it was VTA & there was no way the boost pressure could by-pass the pcv valve increasing internal blow-by.last_resort14 wrote:So it just increases your crank case pressure?
This helped to prevent rear main seal oil leaks,back pressure in the oil drain from the turbo which was causing oil to burn through the turbo seals to the exhaust and oil to drip from the turbo by the oil drain flange.
With my new engine its back to normal apart from a filter on the left front rocker cover exit.
Apparently exactly the same valve but just with a heavier spring. I wouldn't have thought the standard one would lose you one psi though, but then I have done zero reading on superchargers.
Oh and from Fastforward:
PCV valve (323 GTX turbo) -
Purolator PV1014
AC - CV924C
Champ - PC175
Fram - FV275
Motorcraft - EV-146
Mazda #E-301-13-890A
Purolator PV1014
AC - CV924C
Champ - PC175
Fram - FV275
Motorcraft - EV-146
Users browsing this forum: Google Adsense [Bot] and 35 guests
