What petrol do you use?
Post by warrior » Tue Apr 30, 2013 5:42 pm
I, as most of us I guess only uses 95 octane petrol in my car. What I would like to know does anyone use anything else?
Gull has a 98 octane rated fuel but is it any good or just a waste of time? I dont want to open a can of worms here just want to know if there is any point trying the 98 octane rated fuel or not. And if you think it is worth it then where is the best place to buy the fuel?
My car is supercharged and running advanced ignition.
Post by siren676 » Tue Apr 30, 2013 6:12 pm
I use BP 98, running 14° timing so i just use 98 to be on the safe side
Post by WideOpenThrottle » Tue Apr 30, 2013 7:44 pm
Always 98 in my Na as dyno-tuned, while always 95 for the NB
Post by jif » Tue Apr 30, 2013 8:57 pm
91 octane for my turbo'd na8!!
On 30 April 2013 18:12, siren676 <horsepower@mx5forum.co.nz (horsepower@mx5forum.co.nz)> wrote:
Re: What petrol do you use?
Post by Skilfil » Tue Apr 30, 2013 9:14 pm
jif wrote:91 octane for my turbo'd na8!!
Really? Wouldn't that be severely limiting your car even with a tune?
I drove a friends sisters turbo Forester and it was horrendously lacking in power living on 91, stark difference when I drove an older model on 98, felt like a much faster car.
As for my MX5, standard 1.6 running 91. Has exhaust/intake modification but thats it. Nice and frugal. I do wonder what benefits 95 would give me though.
Post by MrGrey » Tue Apr 30, 2013 9:49 pm
I run 91 on my 1.6NA....
I tried 96 for a while, and although the performance was noticeably better, for my general daily driver needs I switched back to 91 simply due to the cost.
with a lot of open road driving, I found fuel efficiency to be slightly better on 96 but town driving (with many stop-starts) I found that 91 and 96 were the same so I chose the cheaper fuel.
Post by REDBEN » Tue Apr 30, 2013 10:13 pm
I only ran 91 on my B6, but with the new motor and setup I will be running BP 98 and E85 later down the track.
Post by authentic » Tue Apr 30, 2013 10:52 pm
What does an orange fuel filler cap signify? I've been told that it means the car requires premium, so I've always run 95.
Or is it just orange for the sake of being bright and colourful like most flammable liquid related things?
Post by brownie » Wed May 01, 2013 12:21 am
Orange fuel cap is Jap for high grade fuel required,Used to see Skylines many years ago when i worked for a importer and RWD Cefiro's,Usually DOHC Turbo stuff,Generally late 80's early 90's stuff of high tune,Later model cars can compensate for crap fuel.
Higher grade fuel does keep engine oil cleaner for longer and does help slow sludge build up.
We see engines in from Japan out of cars from Japan with over 100,000km on them and are like new along the cam gear,Swear some have had no oil they are that clean.
Cars will run OK on 91,but it doesn't do the engine any favors
Post by authentic » Wed May 01, 2013 11:30 am
Ah ok sweet. Thanks for the info!
Post by jif » Wed May 01, 2013 1:07 pm
it had a knock sensor, wideband o2, link ecu and lived like that for years. So it might've done a smidge better on 95 or whatever, but it obviously was close-ish, but not too close to the edge. Basically the FM tune with about 5* added back in .
Definitely not one of those super-retarded (literally) factory tunes. No warranty = no worries !
Having said that, a SC engine will be seeing higher intake temps so there's less safety margin to work with there...
On 30 April 2013 21:14, Skilfil <horsepower@mx5forum.co.nz (horsepower@mx5forum.co.nz)> wrote:
https://www.facebook.com/CalamityProductions
Post by jif » Wed May 08, 2013 3:29 pm
here's a good little summary article, mostly talking about ethanol, but has these little gems in it:http://www.nytimes.com/2013/05/05/autom ... hanol.html
"Using high-octane premium-grade gas in an engine that does not require it offers no benefit."
“You make the dog like the dog food,” and “E15 is the answer to the question nobody asked,”  - Mercedes fuels engineer talking about ethanol... lolz.
On 30 April 2013 17:42, warrior <horsepower@mx5forum.co.nz (horsepower@mx5forum.co.nz)> wrote:
Post by Furai » Thu May 09, 2013 2:41 pm
95, tried 91 and was average in comparison.
Stock 1.6 with 200+K on the clock though, so might get 65HP at the wheels :lol:
But Drift/Gymkahna/road use, and no issues, decent economy.
Post by Kieran » Thu May 09, 2013 2:45 pm
I use whatever the highest octane the gas station has
But for me its more to do with reducing carbon build up than anything else
Post by SLYDIT » Thu May 09, 2013 5:48 pm
i only ever use 98 on the turbo. When running 98 i am only pulling 4 degrees timing at 7 psi...that means you could run stock timing of 10 degrees with my setup. i once did a club run down to wellington and my mpg was exactly the same as the non turbo cars..power and economy...gotta love it!
Post by WideOpenThrottle » Thu May 09, 2013 8:43 pm
Mt turbo cost me $13.00 to go from Muriwai to The BP at the Bombay Hills....and it runs on 98! :D
Post by Skilfil » Thu May 09, 2013 9:05 pm
Well I've been running my MX5 on 95 for a week now. There does seem to be a difference, not more power or anything but it doesn't struggle at low revs as much.
Seems to be running nicely, I think I'll stick to 95. 250,000 k's on the clock as of last week too. Not sure if its just me, but the 95 seems to get rid of some of the tick I had on cold starts? I do regular oil changes but it always came back within 1000 k's.
Mr Revhead
Post by Mr Revhead » Sat May 18, 2013 6:57 pm
93 NZ new 1800, I ran it on 95 for 1600ks in a trip around the SI. I got the same economy as the GF does using 91 around town :lol:
She won't put anything other than 91 in it because it costs more :roll:
On 95 it does seem to run just a little smoother, on 91 it has a barely noticeable stutter around 1500 rpm on part throttle
side note, needs a fuel light!
brooke5
Post by brooke5 » Mon Jul 01, 2013 9:32 am
98 in my standard NA6 err day, will do the same once it has FI :twisted:
'96 Celica - Because DD
Users browsing this forum: Google Adsense [Bot] and 49 guests
