by WideOpenThrottle » Sat Mar 30, 2013 12:02 pm
This is what happens when you try to drill some holes for wires in an old cover!
Next time i will use a soldering iron and melt some holes.
Now to hunt down another.
by harlansmart » Sat Mar 30, 2013 12:19 pm
Whoooosh - I wear Keith's old RPS Carbon instrument binnacle, you can have my old one if you like! - D. Vader
by WideOpenThrottle » Wed Apr 03, 2013 1:42 pm
Thanks to Harlan & some pvc plumbing pipe i now have my gauges relocated as planned to the dash cowling & managed to melt the holes for the wires etc succesfully with a soldering iron....[did a test run first with a bit from my shattered one]!
by MrGrey » Wed Apr 03, 2013 2:09 pm
great job! looks pretty swish
by Timmo » Wed Apr 03, 2013 2:36 pm
I always thought that part would be a good contender for a replacement carbon fibre part (purely for looks)- How hard would it have been to fibre glass the inside and put a thin layer of carbon fibre sheet over the outside?
by WideOpenThrottle » Wed Apr 03, 2013 4:43 pm
Timmo wrote:I always thought that part would be a good contender for a replacement carbon fibre part (purely for looks)- How hard would it have been to fibre glass the inside and put a thin layer of carbon fibre sheet over the outside?
Wouldnt bother with the inside but the outside could be do-able depending on how well the carbon fibre would take to all the curves running different ways.
Might end up disastrous unless you did only the top curvy bit.
by MrGrey » Wed Apr 03, 2013 5:49 pm
for shits and giggles I had a crack at wrapping the shroud with CF vinyl..... long story short, its a complete bastard due to the curves.
if you wanted a CF shroud I would buy one made for it, I wouldn't waste time trying to glue an overcoat of CF on it (I doubt it would have a nice finish)
