Diff oil for a NA
Diff oil for a NA
Post by warrior » Sun Mar 17, 2013 11:13 am
I have just changed the diff oil in my NA and the gearbox is next, my question is: How much oil does a NA diff take?
I thought it was appox 1ltr but I only got 600-700ml in it before it started to dribble out?
Just wanted to know how much it should hold.
Post by Snapfrozen » Sun Mar 17, 2013 11:24 am
Apparantly 1L. Was the car level or jacked up when you did it?
Post by warrior » Sun Mar 17, 2013 1:02 pm
Yep sure was.
Post by siren676 » Sun Mar 17, 2013 1:45 pm
I'll check the fluid capacities in my haynes manual when I get home
Post by warrior » Sun Mar 17, 2013 1:57 pm
Cheers for that, I will recheck level again tomorrow just in case but i,m sure I have done it correct
Post by Furai » Sun Mar 17, 2013 1:59 pm
varies with diff, I had a little left after filling mine but nearly a litre. But mines the NA8, torsen, open and viscous all differ slightly.
Is yours 1600 or 1800?
Post by warrior » Sun Mar 17, 2013 5:00 pm
1600.
Post by WideOpenThrottle » Sun Mar 17, 2013 5:09 pm
its 2l for the 1600. plus a bit for the turret
Post by Furai » Sun Mar 17, 2013 5:10 pm
Then it should only take 600ml.
Post by Furai » Sun Mar 17, 2013 5:11 pm
WideOpenThrottle wrote:its 2l for the 1600. plus a bit for the turret
Diff not gearbox :lol:
Post by warrior » Sun Mar 17, 2013 8:10 pm
Yep 600ml sounds about right for wat i put in
Post by siren676 » Sun Mar 17, 2013 8:35 pm
Cant find the diff capacity in my haynes manual :(
Post by Furai » Sun Mar 17, 2013 10:14 pm
siren676 wrote:Cant find the diff capacity in my haynes manual :(
I just told him what it is :?
Just go to the castrol site to get any oil quantities.
Post by WideOpenThrottle » Mon Mar 18, 2013 5:37 pm
Yup 600mls for the diff [& not the gearbox as i thought]! :roll:
Post by Growler » Wed Mar 20, 2013 1:40 pm
Out of interest what oil did you use?
Post by Skilfil » Wed Mar 20, 2013 1:51 pm
Growler wrote:Out of interest what oil did you use?
Interested in this too, due to do mine.
Post by warrior » Wed Mar 20, 2013 3:18 pm
I used NULON 75W-90 performance smooth shift oil for both diff and gearbox. it is a sythenthic oil and worked great. I also use there oils in ALL my cars and again I cant fault it. SUPERCHEAP sell it but if is very dear ($35.00 lltr). Look on trade me as there are a couple of places selling 4ltr packs (which will do diff and gearbox) for around $80.00 from memory.
