New rear tyres
Simon Lord
New rear tyres
Have to put some new rears on my 97 SR Ltd. Has been on Bridgestone G3's (Dunlop Direzzas on the front). 15 inch rims. My usual supplier tells me 15" directionals are hard to find. What does anyone recommend? I need something that isn't too harsh for everyday use but will hang on when I go for a spirited drive. Need something which is available on the North Shore.
97 SR Ltd (sparkle green)
Email: simon@franchise.co.nz
I have 205/50/15 nitto asymetricals on my NA and 195/50/15 directional Toyo T1R's on the NB and both are spirited grippy tyres.The Toyo's have been used on the track too without any problems althought as with most tyres once they are worn they are not so good in the wet.
From the LTSA website
Directional tyres
If fitted the wrong way:
in the wet, the tyre's tread pattern will effectively dam up water and reduce grip
the tyre could destabilise your car when travelling at high speed.
If moving these tyres from one side of your car to the other, the tyres must be removed from the rims and turned around so that they will rotate in the correct direction when fitted to the other side of your car.
Asymmetric tyres
Some high performance tyres have asymmetrical treads to provide improved handling and performance. These tyres have an inside and an outside tread pattern so that the pattern is not symmetrical across the tread width and must be fitted to match one particular side of the tyre with the corresponding side of the rim, as marked on the tyre. If moving these tyres from one side of your car to the other the tyres must not be removed from the rims and turned around as this will create a tyre/rim mismatch
Directional tyres
Asymmetric tyres
Simon Lord
Thanks for that - I only have them fitted by professionals and always check the direction after. Heard anything about Kumhos?
Simon Lord
Hi guys
I need some more help, please. Couldn't get directional at all - no more Toyos or Kumhos or anything for the 15 inch rim so I tried a set of non-directional Kumhos. They are truly awful and have turned a beautifully-handling little car into something like the automotive equivalent of the HMS Ark Royal. The front turns in and the back... thinks about it for long enough for you to start correcting, then eventually makes its mind up to follow, by which time you are in the process of over-correcting. You go round the corner in a series of lurches and straight lines. It's made cornering more exciting, but only because you're not sure which end is going to come out first. Hardly the typical MX5 experience.
The tyre place will replace them, no problem, but they are as stuck as I am.
So... who had bought tyres for 15 inch rims RECENTLY and what experiences have they had? Or who knows of a secret stock of Bridgestone GIIIs or Dunlop Direzzas? The importers don't.
I can't believe I am the first to strike this problem - if I am, there are going to be a lot of unhappy people in the club soon when their turn comes.
Definately can get T1R's. Can also get RE001/RE11/RE002 which are great tyres. For something relatively cheap, look at Hero HZ1. I have been running mine for 2000km of spirited driving now (195/55/15 or 205/50/15 available). Can't break traction in the dry easily (from standing and dumping the clutch I can, moving, not a chance), in the wet I can light them up in first or 2nd from standing, not if im moving already but they still handle great for a non top level directional.
Sure I know very little, its agreed, but looking now I see attached to my hubs are rims fitted w/T1-R's so snapfrozen is correct, available for certain still.
I also know you can real decent deals on NZH, lots of good JDM rims in 4 x 100 and so you can avoid advanti/rota/konig etc 'copy rims' or hard crappy tires: i.e. the DZ 101 linked to below just for 1 example, but again its agreed I know nothing ok
http://nzhondas.com/wheels/149690-4x-du ... -15-a.html
HK_Fooey
So you asked for advice, received it (from many corners) then promptly ignored it? If your supplier can't find something suitable I'd shop somewhere else - and you haven't even said what model Kumho?!
T1Rs:
http://www.adenstyreshop.co.nz/product_ ... ts_id=2232
http://www.hyper.co.nz/drive/product/de ... ted=163676
T1Rs:
The Toyos TEO's handled very well, I couldnt get either end to break free. They have a slightly softer sidewall than the previous Potenza RE-01 which means softer ride therefore a little more flex on the corners but still handled very well indeed.http://www.adenstyreshop.co.nz/advanced ... 4&x=22&y=4Stevo wrote:I just chucked a set of TOYO TEO Plus all round the MX5 on Monday but I havent used it yet to see how they grip.
Will be doing 500km on Sunday so we will see how they go
I would happliy use them again
Simon Lord
Harlan, thanks for that. I don’t actually want to change wheels as it’s on the originals and I am very happy with the original look of the limited edition.
HK Fooey, I didn’t ignore the advice but at the time I had to get new tyres to get the warrant I had had advice that the Toyo’s aren’t so good in the wet (and it might rain again one day!) and that another member isn’t happy with them compared to the Bridgestones – which is what I am replacing. I didn’t have time to wait for the feedback on the TEO Plus, which I now have and will consider. Although I’m concerned by the softer tyrewalls and the fact that they are a comfort/touring tyre. Have heard some bad things from others about the Hankooks which I let put me off.
Now, thanks to the good people of this board I have a lot more info and, thanks to having a roadworthy (albeit a lot less safe) set of tyres on the back of the car, a bit more time to find a better solution.
Very happy to hear any more feedback.
New rear tyres
We're running Yokohama A-drives on the the bB (195/65x15) but shorter mx5 friendly sizes should be easily find-able. They ride nicely and grip well too. Got them from Bruce Gemmel tyres in Glen Innes.
You get what you pay for
so ... maybe try some Yokohama Advan neovas - OE tyres on the Elise ! Looks like Hyper and Vivid has them.
Monty
pressure
Hi Wideopen throttle, I have just fitted 15inch wheels and Nitto asymetrical tyres to my NA. Fitter recommended 44psi but I'm not sure I like the feel of it. What pressure do you have in yours?
Toyo T1R, Bridgestone RE002, Dunlop Direzza DZ101, BF Goodrich g-force sport; all good tyres although getting hard to find in smaller sizes.
I'd definitely recommend finding someone who will put in the effort to get the right tyres for you. I've been really happy with the service from Steve at Research Tyres down here in Hamilton.
Any particularly good shops up in Auckland?
I am not a tyre expert by any means, but I did have an interesting conversation with the guy at tyremaster here in whangarei....
In a nutshell he was saying that he likes to run his tyres between 30-35 psi and he said he found it amusing that some people run higher psi when (in his opinion) higher psi made a harder ride and made the tyres wear out faster due to less surface contact.
