Your changing entire shock assembly's, no need. When I did want the tophats off I used compressors out of the car. So much easier.Mr. Shine wrote:You don't need spring compressors using the long bolt removal method, and you only need to remove the long bolt for getting the front shocks out; rears pop out nice and easy without!SkilletKid wrote:Didn't think I'd need to remove the upper wishbone? Thought I could get away with just unbolting the swaybar link and levering the whole lower wishbone down.Mr. Shine wrote: Hardest bit to remove I found was the long bolts for the upper wishbone, I'd definitely give them a good pre-soaking!
Do need to get some spring compressors for this I think
Does that not require spring compressors? I know I certainly find them a pain in the ass to use!Furai wrote:Nah thats way hard, I can swap mine out super fast.
There is a hole in the bottom arm, slide a big bar(1M is enough) or rod/tube into that and get one to stand on it while you remove the shock. I usually find standing on it first with all your weight and then bouncing a little.
Yeah, I thought that you'd use spring compressors to shorten the shock length to get it out, I wasn't aware you could get the suspension arms to drop enough to wiggle the shock out without removing the long bolt.Furai wrote:Your changing entire shock assembly's, no need. When I did want the tophats off I used compressors out of the car. So much easier.
Thanks MRgrey!
Havent done it in a few months but Im pretty sure thats it.
From memory its, remove swaybar nut and bolt, then bottom shock nut and bolt. Then put bar in and lever down and it slips out.Mr. Shine wrote:Yeah, I thought that you'd use spring compressors to shorten the shock length to get it out, I wasn't aware you could get the suspension arms to drop enough to wiggle the shock out without removing the long bolt.Furai wrote:Your changing entire shock assembly's, no need. When I did want the tophats off I used compressors out of the car. So much easier.
When I did my car this method was fine for the rears, but the shock/spring assembly was too long in the front and there wasn't enough room to lever it out through the upper suspension arm without getting stuck inside the front fender.Furai wrote:From memory its, remove swaybar nut and bolt, then bottom shock nut and bolt. Then put bar in and lever down and it slips out.
Useful video including the long bolt method is here:
http://www.youtube.com/watch?v=m9iE_76ZMT0
Video shows for an NB I believe, but the method is exactly the same. As Furai says you may not need to use this method, in which case removal for the front is much the same as shown for the rear
I didnt for mine but I did use a 1m long powerbar and 110Kgs of DadMr. Shine wrote:When I did my car this method was fine for the rears, but the shock/spring assembly was too long in the front and there wasn't enough room to lever it out through the upper suspension arm without getting stuck inside the front fender.Furai wrote:From memory its, remove swaybar nut and bolt, then bottom shock nut and bolt. Then put bar in and lever down and it slips out.
The Bilsteins I put in are overall shorter so I can do them by myself.
Yea, the HSDs are a shorter unit to begin with so once they're in they should be easy to take out. The factory ones are really the only issue.
Not sure if I should try find some spring compressors just in case removal goes tits up and I need to try shorten the factory shock.
Not gonna be getting the HSDs for another 2 weeks anyway (unless my resolve to wait it out breaks down =P)
Also wondering if I should bother with getting those adjustable endlinks for the swaybars.
I put on my fibreglass hardtop spoiler today. The spoiler was a pretty good fit but had paint bubbling and dripping marks so I had to first give the top face a sand and repaint. I am no expert but I'm happy with how it came out.
I affixed it using the supplied 3M tape but, (as its a permanent fixture) I used black silicone windscreen sealant on the top edge to seal it off.
I would NOT recommend these spoilers at all.
I strongly urge no one to buy these!
Unfortunately, these spoilers have the nasty side effect of making your car look a hell of a lot cooler and we all know that if usage of these awesome spoilers became more widespread, then the gross median value of 'cool' would devalue based on over saturation of the "mx5's are cool" market.
and that would not be cool.
besides, I wouldn't feel like such a special snowflake if everyone else had one
In all seriousness, these are great and they have broken up the lines enough to take away the fat red sausage look my car was rockin'.
(it was worse, the inner mag rims were lipstick red when I got her before I gave them a repaint)
the best advice I can give with them, is if possible drop into your local bunnings and get some of the same sort of tape but wider so you get better coverage. I used the supplied tape and there were enough gaps for me to warrant using an adhesive sealant to aid the spoiler staying in place.
(you only want to seal the top and leave the bottom open for drainage)
you can get away with a sealant if you are cheap like me and go fibreglass instead of carbonfibre but I think sealant would look crap with CF. so in that instance I would buy more of the weatherproof tape.
Sounds like he is talking about a clutch type lsd to me..i had a cusco one...they wear out way quicker than a std torsen type..especially if raced and drifted etc.Euen wrote:How bad is it? Is it the LSD or the gears? Maybe get Kayne Barrie to have a look at it. He may be able to find some way of resurrecting it.
1998 NB MX5 RS TURBO.
Bang on the money, its a Clutch Type. I purchased a whole NA8 rear subframe when I opened the diff Thought it odd to have a Clutch typemalcster wrote:Sounds like he is talking about a clutch type lsd to me..i had a cusco one...they wear out way quicker than a std torsen type..especially if raced and drifted etc.Euen wrote:How bad is it? Is it the LSD or the gears? Maybe get Kayne Barrie to have a look at it. He may be able to find some way of resurrecting it.
they are very clonky when doing slow turning..its just the way they are.REDBEN wrote:Bang on the money, its a Clutch Type. I purchased a whole NA8 rear subframe when I opened the diff Thought it odd to have a Clutch typemalcster wrote:Sounds like he is talking about a clutch type lsd to me..i had a cusco one...they wear out way quicker than a std torsen type..especially if raced and drifted etc.Euen wrote:How bad is it? Is it the LSD or the gears? Maybe get Kayne Barrie to have a look at it. He may be able to find some way of resurrecting it.
Ok sweet, I do want to keep it, as I like the way it drives but just a bit aggressive on take off, How do I get in contact with Kayne? Thanks Euen are you on Facebook at all I have a couple of question to your motor setup as well?Euen wrote:Have a talk to Kayne. He may be able to adjust the clutch set-up on it (assuming you want to keep it) to make it a bit smoother. He set up my OSG and it is great.
