Spline lug tool
Spline lug tool
Post by Angreal » Sat Jan 12, 2013 9:10 am
So my new wheels arrived and came with spline lugs but no spline lug tool. Does anyone have one I can borrow to swap them over and get them into the car?
Post by dylann » Sat Jan 12, 2013 10:17 am
You can pick one up at mag and turbo for $25 or so, Im sure other tyre shops would sell them aswell, just gotta bring a nut in for the pattern
Post by Angreal » Sat Jan 12, 2013 10:21 am
Awesome. Guess I'll do that then
Post by Snapfrozen » Sat Jan 12, 2013 10:24 am
If you aren't having luck finding one, alot of people call them Tuner nuts/lugs
Post by Snapfrozen » Sat Jan 12, 2013 2:03 pm
And if you are really struggling post up a pic in case it's different but you are welcome to come to Pakuranga and borrow mine
Post by Angreal » Sat Jan 12, 2013 2:21 pm
Managed to grab the last one in their shop that fit :D So much to install, so little motivation
Post by Angreal » Sat Jan 12, 2013 3:08 pm
Anyhow, change in topic but doing under the same job I guess... Put the first new wheel on with the spacer (needed to clear the 4pots at the front) while removing the front fender to put in the frog arm, how will I know if I need to roll a guard or not? the wheel pokes out slightly?
I guess I'll take a photo when I'm all done and put it up when my internet stops playing up
Post by siren676 » Sat Jan 12, 2013 4:00 pm
Angreal wrote:Managed to grab the last one in their shop that fit :D So much to install, so little motivation
Invite all the Auckland members over 1 weekend and get it all fitted :lol:
Post by siren676 » Sat Jan 12, 2013 4:07 pm
Angreal wrote:Anyhow, change in topic but doing under the same job I guess... Put the first new wheel on with the spacer (needed to clear the 4pots at the front) while removing the front fender to put in the frog arm, how will I know if I need to roll a guard or not? the wheel pokes out slightly?
Depends. What wheel specs, tyre size and spacer size are you running?
Post by Angreal » Sat Jan 12, 2013 5:23 pm
RPF1 +41mm offset, 15x7 and a 15mm spacer, maybe should've opted for the 25mm but I do like subtlety. The tyre pokes out a tad...
Post by Angreal » Sat Jan 12, 2013 5:28 pm
That would be awesome finally having everything installed :-D getting there slowly...tediously slowly tbh
Post by siren676 » Sat Jan 12, 2013 5:41 pm
Angreal wrote:RPF1 +41mm offset, 15x7 and a 15mm spacer, maybe should've opted for the 25mm but I do like subtlety. The tyre pokes out a tad...
I assume you are running 195/50's? If so they may need a slight roll depending how low you go and the amount of camber you run
Post by Angreal » Sat Jan 12, 2013 6:00 pm
1.5 degrees and not planning too low due to bottoming out on my bracing.Guess we'll see when I eventually finish... I'll get there one day :wink:
