Dont worry its been considered, 60Kg less and 200 odd PS...Donovan wrote:Go NA, just use a 13B bridgeport, yeeehaa.
Only issue is fuel consuption for a daily.
I want a little bit more power but still driveable everyday. So more torque really. A ported 13B will drop that economy quickDonovan wrote:Pah, used to get under 10l/100 in my SIII RX7 with a 13b out of a series 4. Get a Rensis engine then, better economy out of one of those
I see that Mazda are making noises about making a RX9 based on the new MX5 platform. Hopefully they do, will be back to the weight of the first gen RX7's.
Anyway, what do you want. more power or better economy, the two don't go together (unless you go newer technology in a new motor)
2L out of an NC then??
Well I still have a long way to go and might change my mind, at the moment Im goign to upgrade the cooling, then Rollbar or brakes, and just get it set up for more power.Donovan wrote:A J port or monster port yes, but a bridgeport, not so much. Just could do a mild port, since the 13b is making more torque than the 1.6 no worse off, just more economy wise.
Which I imagine if you squeeze more HP out of a NA engine your economy will suffer anyway. Anyone that tells me that they are putting more HP into an engine, and still going to drive it like a nanny around town so that the economy is no worse is a liar. Been there done that. If you have more power, chances are you going to use it, no matter how restrained you are.
This intrigues me. I have also seen this phenomenaWhat you are saying is quite correct, the reason Im quite fixed on NA is more the Balance and response. I am forever seeing videos of NA cars with less power than a Turbo version going just as if not more quickly.
I guess you wouldn't post up a video of you being passed by everyone in your $10K NA Engine?Mad Kiwi wrote:
This intrigues me. I have also seen this phenomena![]()
But I wonder if the guys that are punting around well in a NA mx5 would not be quicker again in a more powerful MX5. I get the feeling we see and recognise these situations becasue they are unusual and more a reflection of the driver quality and car setup skills than the naturally aspirated and "balanced" car...
There really aren't many stories of MX5's being overpowered and not handling well due to excess power. .....That I have seen at least.
I will have to take you up on that offer, see what all the fuss is about.Mad Kiwi wrote:Furai, what I see here is a lack of experience....not driving experience but having a go in a turbo'd car experience.
That vid you posted. ANY car would have problems in those conditions with whatever tyres he had.
I sincerely believe you have built up the NA v Boosted thing in your head to be a bigger issue than it really is (too much forum time i think......something I am vulnerable too as well I might add)
Anyway, what I am saying is that as soon as my car is sorted with paperwork etc you are welcome to take it for a drive on the street / motorway etc and even a go around Hampton next time I am there. You have the skill, of that I am in no doubt.
A real good example would have been the old turbo Motor that Kasey is going to install at some point. That comes on 6psi boost at 2500-2700 and is a sensation to drive. Not crazy but really torquey and just lovely.
My new motor is a bit less fun as it comes on to 8 psi boost a lot harder at 3600-4000 but even then is really driveable...(i have yet to turn it up to the 10 Keith was running, it needs some fine tuning in it's new enviroment)
So time to stop wondering and time to have a drive and find out for yourself properly!
To point out with 1.5k my EG civic on a 1.6L engine made 140wkw. Guarantee ITB's on an MX5 won't even come close to outperforming that. Ran a 13.8 quarter and I would have to pull my lap times but I was mid pack in Honda cupSkilfil wrote:
Do you want your MX5 to take a dump in a Hondas sandbox with its own screaming N/A? Then ITB your heart out.
This is what my built engine will be about. Boost the entire way, nice smooth dyno curve and just a bit of extra punch.That comes on 6psi boost at 2500-2700 and is a sensation to drive. Not crazy but really torquey and just lovely.
Yeah to get near a Honda you'd have to be doing some fairly decent N/A mods. Probably get bugger all out of a MX5 1.8 with 1.5k spent.Snapfrozen wrote: To point out with 1.5k my EG civic on a 1.6L engine made 140wkw. Guarantee ITB's on an MX5 won't even come close to outperforming that. Ran a 13.8 quarter and I would have to pull my lap times but I was mid pack in Honda cup
They are in a spec racing class and need every last ounce to be and the top. I have several dyno sheets showing just ITBs on an engine getting between 116WHP to 125WHP.Snapfrozen wrote:Google the US Spec Miata's. They're making about 120-150whp and throwing 10k at engines... Blueprinted engines, port and polish, exhaust, intake (Think theyre limited by cams...)... and need a rebuild every 10k
