http://www.trademe.co.nz/motors/car-par ... 436671.htmSLYDIT wrote:if anyone has any parts such as CAS/ignitor/coilpack/ECU that they dont mind lending out please let me know.
OH FFS! car wont start!
I tried listening for it the other night but could only hear the relay clicking on and off, fuel line was probably still pressurised so the pump didnt need to turn on.SLYDIT wrote:my fp is loud...always has been. turn your radio off and listen in your garage. you probably have no hope outside on the road. you wont hear it with the engine running.
Will try in the morning before heading to work
SOLVED!
Seeing as the car wasnt going anywhere, i decided to do a bit of other work on it.
I pulled the ECU to give the ecu bracket some paint so pulled the covers off and discovered corrosion on the 1A/1B/1C pins on the ecu plug where they join the board so cleaned it up and resoldered the connections and hey presto. car is back to life. Fuel pump still doesnt run in acc like it did, but everything seems to be ok...oh well off to whangamata this weekend!
*\0/*
*\0/*
