Gearbox and diff oil
Ok time to change the diff and gearbox oil....this is what I am going to use from recomendation of FLYIN MIATA
GEARBOX: REDLINE MTL 3 QUARTS
DIFF: REDLINE GEAR OIL 1 QUART
Any comments you have would be great
One question....I am going to cange the oil in the gearbox turret as well but how much does it take in mm? Cant seem to find it anywhere and also does it just go into the hole that the gearlever goes into?
Gearbox capacity is 2 litres. Most people tend to use Redline MT90. A good synthetic SAE80W/90 that meets API GL4 or GL5 should be fine.
From memory you only need about 30ml of oil in the shift turret.
The Mazda NA workshop manual specifies the following for the diff
Above -18*C : API GL5, SAE 90
Below -18*C : API GL5, SAE80W
Capacity: 0.65 litre
I've been meaning to do the turret oil in my car for a while now. I guess I just remove the gear knob, remove console and then find some hole to suck oil out of and top up?
I also have the big and small boots that I've been meaning to replace at the same time, is this self explanatory once I've pulled everything out?
You need to remove the gear lever to top up the turret. If there is oil in there I wouldn't bother with sucking it out, it is not under any stress. You just need to make sure that there is a bit in there.Angreal wrote:I've been meaning to do the turret oil in my car for a while now. I guess I just remove the gear knob, remove console and then find some hole to suck oil out of and top up?
The big boot needs to come off to get access to the turret. The small boot is held in place by the same bolts that hold the gear lever in place. You may need to cut off the small one and then slide the new one down over the gear lever. A bit of detergent or vegetable oil might help to slide it on.
Thanks. Might get onto it before summer if all goes to plan and I stop being lazyEuen wrote:You need to remove the gear lever to top up the turret. If there is oil in there I wouldn't bother with sucking it out, it is not under any stress. You just need to make sure that there is a bit in there.Angreal wrote:I've been meaning to do the turret oil in my car for a while now. I guess I just remove the gear knob, remove console and then find some hole to suck oil out of and top up?
Just a heads up on oil. The new oil to use which is supposed to be even better than redline, is motorcraft fully synthetic. Not cheap and only available from ford dealers. It is supposed to be the magic oil for manual gearboxesthere has been a huge shift from redline over to motorcraft in the last year or so.
I think mobil 1 has become the diff oil of choice now for non lsd diffs
