Suspension and track times Disscusion
Correct. Personally don't like Puke, its unforgiving in several places and I'm not comfortable pushing 110% on it in case of errors. Love the full Taupo track, would be my favourite track in NZ. 1:05 sounds about right. Those were my fastest times, averaged about 1-3 seconds slower than those.
Just saying, I know where my limits are in the car, no point in worrying about them when I'm making 90rwhp lol
If you can't reach the limit of his suspension, why upgrade it? That was my pointAngreal wrote:I'd be very scared to try reach the limit in Donovan's carSnapfrozen wrote:My next option would be to look at the middle to top Fortune Auto coilovers with custom rates on them, but until I hit the limit with how I can perform driving on these, theres no point.
I was doing 1:11's at Puke and 1:20's at Taupo in a near stock engined car, run to your limit. THEN spend money to make yourself faster, this poor bitch has barely seen the track yet, let alone hitting the limit driving her
Yeah I had a look at that but didnt want the cert. I found a set of Bilstein Coilovers PSS-9 for $1500 about 3 months old but add on the annoyance of a cert and no being allowed to adjust I lost interest.Donovan wrote:When I was chatting to the Autolign guys at Albany about trying to find some hard to find Springs for my Tein Coilovers, they said an option would be to get Bilstein's with the circlips, and then apparently they do a tread kit or something that you remove the circlip and can put in platforms that turn them into a sort of coilover, think it was about $800-$900 or something?? Don't quote me on the price, cause my memory is shocking, but it was cheap.Snapfrozen wrote:Coilover setup that is comparable would be about $2200. Quite prepared to run aftermarket shocks, with aftermarket springs, that have been revalved t suit the height and stiffness I want.chris wrote:Or just spend a little bit more and get coilovers..
No difference between that and coilovers other than the fact I can change the height whenever.
Mad_Kiwi was also running HSD coilovers in his (before getting Keith's Koni's) which I think are about $1500, and a few of the reviews that I read about them said that they were not too bad. Dodson do these.
I got my Tein coiloversprings from the states(in transit now) as Autolign would take about 2 months to get them which I couldnt be bothered waiting. $430 shipped for the whole set.
What rates? Your shocks are still factory valved right?Furai wrote:Yeah I had a look at that but didnt want the cert. I found a set of Bilstein Coilovers PSS-9 for $1500 about 3 months old but add on the annoyance of a cert and no being allowed to adjust I lost interest.Donovan wrote:When I was chatting to the Autolign guys at Albany about trying to find some hard to find Springs for my Tein Coilovers, they said an option would be to get Bilstein's with the circlips, and then apparently they do a tread kit or something that you remove the circlip and can put in platforms that turn them into a sort of coilover, think it was about $800-$900 or something?? Don't quote me on the price, cause my memory is shocking, but it was cheap.Snapfrozen wrote: Coilover setup that is comparable would be about $2200. Quite prepared to run aftermarket shocks, with aftermarket springs, that have been revalved t suit the height and stiffness I want.
My race car does 1.08's! I could get 1.20 out of my fairly standard MX5 chasing a Datsun 1200 Race Car...but that was with a slight drift into the last corner before the back straight so I could maintain the speed.Snapfrozen wrote:I was doing 1:11's at Puke and 1:20's at Taupo in a near stock engined car, run to your limit. THEN spend money to make yourself faster, this poor bitch has barely seen the track yet, let alone hitting the limit driving her
I dont think you would have more spring travel unless your using NB tophats, especially if your running lower than me(Im about 310mm hub to arch height all round.) so about 130mm from the ground.Snapfrozen wrote:Man thats gunna be a rough ride if you daily it haha. Im about the same but have more spring travel than you I think
But I dont think I will have a rough ride with the right valving, only one way to find out though
Edit:I dodged potholes even with stock suspension(Small car and small tyres will never take bumps that well)
Fortune auto coilovers are crap they leak oil ive seen 6 mx5s on clubroadster that have switched from Fortune auto to StanceSnapfrozen wrote:My next option would be to look at the middle to top Fortune Auto coilovers with custom rates on them, but until I hit the limit with how I can perform driving on these, theres no point.
The customs rates on them are just an upgrade to swift springs which you can get at lots of different rates
HSD coilovers are a rebranded Stance coilover and Swift makes springs for all coilovers
So i would just get HSD's and put some swift springs in them
Also most track driven mx5s run what you consider a "cheap coilover"Snapfrozen wrote:Thing is, theres no point in me buying cheap coilovers. They are going to get fucking raped on the track. Bilsteins are rebuildable, they have the exact rates I want, and theyre brilliant quality (no point putting cheap sleeves on them, I can get the desired height without coilover sleeves).
they all cant be wrong
Custom valved Bilsteins > cheap coilovers. At least my shits rebuildable when something goes wrong.
As far as the Fortune Auto's go - Can get em cheap, and won't use Tein again after bad personal experiences with a few sets. I've felt the difference with cheap coilovers and good ones on the track and don't think its worth it.
6 coilovers leaking on clubroadster are hardly "bad failure rates". Most guys on clubroadster wind their coilovers as low as they can and hardpark. Won't be doing much of that.
Google "Stance leak shock". Just found like 39843439 of them leaking. Must be shit
My tein's are rebuildable/revalvable and were pretty cheap. What was wrong with your tein's? Mind you I'm still sold on the Ohlins purely based on my mates R1 that was running Ohlins where suspension plays a much bigger role in not dying on the bikeSnapfrozen wrote:Custom valved Bilsteins > cheap coilovers. At least my shits rebuildable when something goes wrong.
I don't get what you mean at all.Snapfrozen wrote:Exactly. You get what you pay for. Theyre still a cheaper end of the market coilover.
Take a file to the inserts on a Bilstein and I guarantee the file ends up worse off. Thats freaking tough.
For $1250 they are great? I have tracked them and they are awesome?
I have a friend in Japan who runs Ohlins at the same rates Im getting. Have to be honest they are the BEST. Bilstein a close second. But you pay for the best.Angreal wrote:My tein's are rebuildable/revalvable and were pretty cheap. What was wrong with your tein's? Mind you I'm still sold on the Ohlins purely based on my mates R1 that was running Ohlins where suspension plays a much bigger role in not dying on the bikeSnapfrozen wrote:Custom valved Bilsteins > cheap coilovers. At least my shits rebuildable when something goes wrong.
Problem was the cost to rebuild vs the amount of time rebuilds take. Autolign can use in shop parts instead of the "recomended" parts which are the problem to begin with. Also didnt end up with the ride quality I was expecting after paying the amount I paid for them. Personally, felt my Buddyclubs outperformed them for $500 lessAngreal wrote:My tein's are rebuildable/revalvable and were pretty cheap. What was wrong with your tein's? Mind you I'm still sold on the Ohlins purely based on my mates R1 that was running Ohlins where suspension plays a much bigger role in not dying on the bikeSnapfrozen wrote:Custom valved Bilsteins > cheap coilovers. At least my shits rebuildable when something goes wrong.
If you spent the same amount of money on coilovers that I spent on my Bilsteins, you would end up with leaky shit for the max amount of abuse they would take.chris wrote:I don't get what you mean at all.Snapfrozen wrote:Exactly. You get what you pay for. Theyre still a cheaper end of the market coilover.
Bilsteins are close to indestructable, and when they DO fail, they are rebuildable, which cheap coilovers arent. Tracking a set of coilovers once won't prove anything.
When you combine good tyres, brakes and suspension (and you can drive), you end up fast. I've got one of those 3 nailed. No point getting my semi slicks until I have my wheels, and not rushing into heavy wheels so hanging out for the right set. Brakes are simple, good fluid, rotors and pads with an upgraded MC/Booster and you can stop on a dime on the track. Then once I hit my limit there, I turbo it and keep going.
Sorry don't think I said that I had only tracked it once?
I find the adjustable coilovers to be brilliant in that I can adjust the dampning so when I'm riding it doesnt feel like I have anything riding me from behind 24/7.. You know unless that's what you're into..
Done hampton a few times now, Pukekohe once, not that I have any clue of that lap time.
The best I got round hampton I think was 1.30 - 1.33
My mx5 is stock in the bay. Strut brace, roll bar, buckies and OZ Racing Adjusties.
And no, they weren't "going down"
Users browsing this forum: No registered users and 60 guests
