Energy Suspension Diff Bushes
Just seeing if anyone else wants to order a set of these:
http://949racing.com/diff-mount-bushings-miata.aspx
I will make a inquiry into price tomorrow, then we can all save on shipping.
Ben
Ben
Straight from the horse's mouthMad Kiwi wrote:I am tempted but what are the suggested / known advantages of these?
"These bushings locate the differential housing and greatly reduce movement. You'll notice wheel hop is reduced or eliminated and much improved shifting. The shiftingimprovement comes from the trans/PPF assembly not rocking back and forth as much. Take a look at your shift lever when you let the clutch out, that movement is your motor and diff mounts letting stuff move around. The ES diff mounts will transmit a little more vibration but nowhere near as much as sold Delrin or aluminum mounts."
This shows you how to do it all.warrior wrote:how hard are they to install?
http://www.youtube.com/watch?v=xBpIJLHZuSI
Or lose it modifying mx5's!Furai wrote:If you cant afford $100 then your bad with moneyBorn_disturbed wrote:FixedREDBEN wrote:Ok Guys I will hold off until the 6th October how does that suit? Must just be me super RICH
why don't you buy the full energy bush kit for like $350 or so?
it comes with the diff bushes and you might actually feel a difference when you drive the car,
i hate to say it but of all of the bush kits i have put in, there is no noticeable difference between the ones i put the diff bushes in and the ones that i havent
There are some perks working for New Zealands Biggest Auto Parts supply storesprsta wrote:why don't you buy the full energy bush kit for like $350 or so?
