- I only think 5.
by warrior » Tue Sep 11, 2012 11:32 am
Has anyone got any 15mm spacers (or maybe some other width) I could borrow? I would like to get a little more width in my car but it is quite low so just want to borrow some spacers before I buy to make sure the wheels wont rub......anyone? please?
- I only think 5.
by warrior » Tue Sep 11, 2012 11:33 am
For a na. Cheers
by WideOpenThrottle » Tue Sep 11, 2012 11:57 am
Washers or wheel nuts??? dont drive it tho!!
by Keith Jones » Tue Sep 11, 2012 2:48 pm
I've got a couple of 10mm spacers you could borrow.
However, even they need longer studs. So as Gary said, don't drive it.
by sprsta » Tue Sep 11, 2012 3:07 pm
i have some 15mm ones you can try but the hub bore is too big for an mx5 but they will likely fit if you have aftermarket wheels
- I only think 5.
by warrior » Tue Sep 11, 2012 3:32 pm
sprsta.......I do have aftermarket wheels. Do you know the size of the bore so I can check if they will work? I had some for my MR2 and they did not need longer studs as they were the type that bolts onto the hub....are these the same as that? I need to drive with them on to make sure they dod not rub etc over bumps
by sprsta » Wed Sep 12, 2012 6:54 pm
the bore diameter is 75mm they are bolt on's
- I only think 5.
by warrior » Wed Sep 12, 2012 9:30 pm
Cheers, I will pm you
