r3spct
Post by r3spct » Tue Jul 03, 2012 11:12 pm
I was fortunate i got mine into a carport for storage, im moving house and its normally in the garage but was going to put it on the road. The roof on mine is def a bit rough, has a couple of patches over drivers seat that were weeping, and dribbles around the windows a bit.
My sister rang me later and told me the carport flooded a little and it ended up sitting in about a inch of water, wouldnt have got any worse than that due to slope, but still.
Post by Furai » Wed Jul 04, 2012 10:07 am
Sucks you got water in, Im glad I have a hardtop!
Post by punkoutnz » Wed Jul 04, 2012 10:36 am
Yeah mine was dry as a bone when I hopped into it after work, and it wore the brunt of the rain. Dad's landrover had water dripping from both sun roofs, haha.
Post by Furai » Wed Jul 04, 2012 10:52 am
I get raised undercover parking at my work :lol:
Zadkiel
Post by Zadkiel » Thu Jul 05, 2012 5:48 pm
Hardtop all the way for mine, sat out in the rain taking a pounding, no leaks at all. It get to live inside at home, but not at work. :(
Post by Mad Kiwi » Sat Jul 07, 2012 7:20 pm
As i have been concerned with under bonnet temps for the track days, Car didn't overheat on the evening track day but start to register hotter than normal as slowed down on the pull in lap.
I figured it was time to add the bonnett lovres from Fling Miata that came the other day with my bits and pieces.....
Post by Mad Kiwi » Sat Jul 07, 2012 7:26 pm
The final result.....Have stayed with Black as that is the colour of the roof and I haven't decided on a body colour for the re spray yet (eventually that is...).
Will run with the satin black for the time being....
Post by harlansmart » Sat Jul 07, 2012 8:19 pm
Looks good Mark!
(Black is Best, Black is Bad)
Post by Furai » Sat Jul 07, 2012 8:49 pm
Looks really neat, like some of the rather exstensivly modified Roadsters but the subtle look is nice too.. I think I dont wanna drill holes :lol:
Post by evel » Sat Jul 07, 2012 9:38 pm
well I found out what brake fad feels like going down mountain road :lol:
Post by Angreal » Sat Jul 07, 2012 10:00 pm
Yes brake fade is not fun but with new fluid it seemed to stop it going spongy on me. Worst fade I've had was at Hampton on the bike. After the main straight where you'd slow down from over 200 there's a second smaller straight where i'd get to 150 but always struggled to slow it at the end... Not fun
This weekend I sorted out my headlight popup switch finally after doing the nb interior swap a year ago
Post by Ian » Sun Jul 08, 2012 1:49 pm
Fitted a second tiedown ratchet mechanism to my (MX5) transporter trailer....would hate to get halfway to the circuit and see only an empty trailer behind me!
ham
Post by ham » Sun Jul 08, 2012 4:59 pm
Ditched the 17s and replaced with 15s. Huge improvement in ride quality and seems to handle better so plus all round
1989 NA Blue JRSC.
Post by Euen » Sun Jul 08, 2012 5:06 pm
Ian wrote:Fitted a second tiedown ratchet mechanism to my (MX5) transporter trailer....would hate to get halfway to the circuit and see only an empty trailer behind me!
I've heard of it happening to others, fortunately not me.
One problem with many of currently available ratchet tie-downs is that they can stretch and with no retainer on the hooks, the hooks can disconnect, leaving you with an insecure car on the trailer. I don't trust the hooks any more.
Post by Euen » Sun Jul 08, 2012 5:11 pm
Have just stripped and repainted the rear subframe and suspension arms I bought from Donovan in preparation for new Energy bushes and, initially, a 4.3 torsen. Still have to strip the hubs and uprights but it is a bit tricky trying to undo the hub nut on the bench.
Post by SLYDIT » Sun Jul 08, 2012 6:41 pm
after seeing Sprstas car in a shopping mall yesterday, i decided mine needs some more lower and a spruce up so i got stuck in to my door cards today.
Post by siren676 » Sun Jul 08, 2012 7:26 pm
Had to defrost the car this morning so i could go to work. :lol:
Have decided that i need to get a hard top
Post by punkoutnz » Sun Jul 08, 2012 7:35 pm
That canvas top doesn't offer much comfort against ice does it!
Zadkiel
Post by Zadkiel » Sun Jul 08, 2012 8:29 pm
Put my Apexi suspension in. Much lower now.
Post by Donovan » Sun Jul 08, 2012 10:17 pm
Got the stereo working again, fitted the new Momo wheel, found and fixed a leak in the coolant track, and then took the wee bestie for a cruise to TeKawhata to pick up my daughter from her cousins place that she was staying at, about 150k's on quarter of a tank.
Post by WideOpenThrottle » Mon Jul 09, 2012 9:44 am
Finally fitted my IC & pipes ready to be all welded together this week hopefully along with my coolant re-route mod & air intake sensor bung! :D
Mock -up filter position
Intercooler in place
Post by Mr. Shine » Mon Jul 09, 2012 2:22 pm
I pissed coolant all over the forecourt of a petrol station this weekend :lol:
Appears to be a leak from the thermostat to water pump bypass hose, which fortunately John Andrew Mazda appear to have on the shelf, so it's being picked up as I type. Have the heater and top/bottom hoses at home ready to replace, and will pick up the other three bypass hoses to replace on Saturday.
Will replace the split hose tonight, and the rest will be fun for this weekend!
r3spct
Post by r3spct » Mon Jul 09, 2012 5:36 pm
Got 2 new heater hoses for $32 the pair from my hookup at mazda, chur bro...
Post by Mr. Shine » Mon Jul 09, 2012 7:36 pm
My fix may not be so simple, it's still seeming to leak out of the same spot even after fitting a new hose, which is rather frustrating.
Any suggestions? The hose is the thermostat to water pump inlet, and it's leaking from where the hose goes over the water pump inlet...
Suppose maybe I should just get the cambelt done and replace the water pump, water pump inlet and thermostat housing/cover...
Post by Ian » Mon Jul 09, 2012 7:37 pm
Hi Euan..
On the front I am using custom straps through each wheel, then a HD bow shackle to attach each strap to its respective 1 metre strap straight back to each ratchet. At the rear I have HD tiedowns with the 'triangular hook keepers' which Aerofast supplied for me- again 1 for each wheel. Call me anal but I specified my nylon winch rope with a retainer type hook, and this is connected to the front towing eye.
Have always made a point of stopping 10ks into any tow to check tensions. Truckies are usually advised to check their loads every hour...I tend to do the same plus trailer hub temps. New trailer is a tandem so there is a bit more peace of mind over the previous single axle jobbie. Can't believe how many transporters I considered (briefly) that had no trailer brakes!
Grins
