Question about fitting exhaust systems
Kind of a noob question, but I've never delt with an exhaust system properly myself.
I'm looking at completely replacing my stock-ish exhaust system. Headers, midpipe, muffler, the works.
I've settled on a Racing Beat 4-1 header, and liked the idea of going with Racing Beat everything (test pipe to repace the cat, sport midpipe and single tip muffler) but I prefer the look of the Buddy Club Spec II exhaust system.
My question is basically, would everything fit together? I assumed that the 'length' of aftermarket headers is always the same, so the outlet flange is always going to sit at the same place. But I'm checking here first.
Thanks to Kieran in my thread 'Buying from the states' for suggesting MiataRoadster.com. I emailed them this afternoon and they already got back to me with a shipping estimate for a set of headers ($142 USD, not bad).
Whats the legal limit, is it something like 90db at 4K rpm?
I watched a couple youtube videos to try and see how loud they are (they both sound awesome), but theres no way to tell by listening to camera phone audio through headphones
Buddy Club Spec II on an MX-5: http://www.youtube.com/watch?v=t_q_k0sR ... page#t=33s
Racing Beat system on an MX-5: http://www.youtube.com/watch?list=FLGwA ... page#t=40s
The Racing Beat system has a couple of options for the midpipe, one being a pre-silencer which would help cut down the decibels.
As far as volume goes, if your WoF shop goes by the book, ANY buddyclub exhaust will fail a WoF.
As far as silencers go, technically they have to be welded in as per WoF or LVVTA noise cert requirements, so once again, going by the book you should fail if it is removable. My recommendation, keep your stock exhaust for WoF's if you run into trouble.
I had a 2.5in stainless exhaust, 1x cat, 1x mid muffler, 1x twin loop muffler and with a gasket to reduce the c pipe size to 2x 1.5cm holes, I was still failing noise certs on my civic.
Edit*
The other thing with noise tests (Not sure about MX-5's, but 4 bangers usually do) I was failing due to the growl/cackle/horrible noise as they backed off the throttle, which is counted in the test, not the accelleration itself)
Edit*
Hi have headers, one silenser and a jackson racing muffler and the car is too loud, the thing is i,m over 40 and my car is in very good condition. I use a GOOD local warrent place that I am very nice when I go there and take all my 4 cars there for a warrent. They have told me the car is too loud but have passed it every time because of the reasons I have listed.....just my 2 cents worth.
This is the sort of thing the local guys can do!...i have no complaintsauthentic wrote:I did think about going local for sure. I just went searching for headers and came across those systems which seemed pretty sweet.
Would an exhaust shop be able to source headers, or would it be best to get some myself and take them in?
What spec's is your car ???,Put in in your sig,always makes it easier to help if we what you have.
I've a Racing Beat muffler(By RS*R Japan) and pipe i bought that i,m not going to use now.
To suit NA 1600,should work on a 1800 NA as well.
PM me and i can send photos if keen,Pretty sure i,ve posted photo's of it before on the forum
There are a couple of places in penrose that sell headers for the NA , i bought mine from them and had them fitted. I am very happy wth the quality of them (I will get there name for you) Then I got a JACKSON RACING muffler off trade me and got AL,S mufflers to fit it all up. Cost was appox $850 all up fitted. Give me a couple of days and I will get there names but one is DRIFTMAX.
That looks sick, definitely wouldn't have any complaints with that!This is the sort of thing the local guys can do!...i have no complaints
I saw those Drift Max headers on trade me a while back, which would have been just right. But I was working 12 hour night shifts at the time and repping a 50cc moped to go to work so I wasn't focused on my car at the time. They're out of stock at the moment and they cant give an estimate on when new stuffs going to come in.There are a couple of places in penrose that sell headers for the NA , i bought mine from them and had them fitted. I am very happy wth the quality of them (I will get there name for you) Then I got a JACKSON RACING muffler off trade me and got AL,S mufflers to fit it all up. Cost was appox $850 all up fitted. Give me a couple of days and I will get there names but one is DRIFTMAX.
PM'd brownie.
The numbers they quote are no where near accurate... Cant confirm for MX-5's. Ive been black flagged at Puke using a spec 2 at over 100dB with a cat2low2c wrote:all buddy club exhausts will pass a wof for noise if the factory cat is still in the jasma spec is 90db with the cat in. i would suspect even the racing beat exhaust might be to loud for the road if you remove the cat .
From what I hear the collector and primary tubing on all off the shelf miata headers are to small if you do any head work, Cams, oversized pistons, hi-comp, etc...
So if your modifing the engine at all there is no point in getting a RB header as like most other off the shelf part for a miata or any car they are meant for max efficiency on a stock engine same with the rest of the exhaust from them and anyone else if you arent planning any future engine work go hard they make good quality products and sound nice!
Any increase over factory noise output requires LVV testing and certification, and certainly at least the Spec II is louder than factory, and on top of that it has a removable silencer, which is not allowed. I'd expect other Buddy Club exhausts to be at least slightly louder than factory also.2low2c wrote:all buddy club exhausts will pass a wof for noise if the factory cat is still in the jasma spec is 90db with the cat in.
Sorry Kieran, this is not correct. The RB header will not 'strangle' naturally aspirated outputs, short of a stroker. Cheers.Kieran wrote:From what I hear the collector and primary tubing on all off the shelf miata headers are to small if you do any head work, Cams, oversized pistons, hi-comp, etc...
I've got the rb mid-pipe in the garage and the rb power pulse muffler coming over in a container and currently installed is maxim works headers. I'll let you know what its like when they're all installed. I plan to put in the flyin miata cat though to replace the test pipe I currently have. Shouldnt be too loud from what ive seen on YouTube
Those Maxim Works headers look real nice, I first saw them on the REV9 website a while back. Where abouts did you get yours?Angreal wrote:I've got the rb mid-pipe in the garage and the rb power pulse muffler coming over in a container and currently installed is maxim works headers. I'll let you know what its like when they're all installed. I plan to put in the flyin miata cat though to replace the test pipe I currently have. Shouldnt be too loud from what ive seen on YouTube
You should make a quick video when its all installed, would be cool to hear it in action.
Picked them up by chance from mazline. My old headers kept splitting so I went on a mission to make my car wofable and took about 2 months to find anything that would fit and by chance these were the first things that fit hence I coated them with hpc to ensure they last. As soon as I saw them I knew I needed them and are pretty much why I'm looking to supercharge rather than turbo.
Slightly OT, but does a pod filter cold air intake make the stock engine sound a bit better?
Im kinda a bit bummed about how un-sporty the engine sounds, im tempted to go turbo just to cover the horrible noise of the engine with sucking noises.
Exhaust is stock, might do a system for it at some stage.
